Question about Troy Garden
Troy bilt trimmer TB525CS idle clutch dose not disengage
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
SOURCE: Line replacement on Troy-Bilt TB525CS trimmer
This was my problem as well when I initially purchased. After letting it sit for a week due to frustration...I tried again. I believe that the manual is wrong when it states that the winding is clockwise and could cause the teeth to eventually wear down. I watched the motion of the speed spool when I gently tugged on the line simulating the centrifugal force...there is no way that you can wind it clockwise and expect it to stay. I simply wound it COUNTER-CLOCKWISE to get the desired result. I finished trimming the lawn and had no more problems...except for learning that I cannot edge along concrete without the line wearing quickly.
Posted on Aug 17, 2009
SOURCE: how to change trimmer ine in tb525cs
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
Posted on Jul 19, 2010
SOURCE: Cannot disassemble Troy-bilt trimmer head
There is a round, rotary black part between the metal piece to which the cutting head attaches and the outer plastic seat of the cutting head. There are two square slots, each about a quarter inch wide, on opposites sides of the black piece. Slide an Allen wrench or something similar firmly into the slot. Holding the Allen wrench in a stable position, turn the outer plastic ring of the cutting head (it has scalloped edges that can be gripped firmly) counter clockwise to unscrew the cutting head from the bolt on which it is mounted. Be careful with the tool (e.g. Allen wrench) used to hold the black piece steady, as it is plastic and could be damaged by the edge of the tool.
Posted on May 04, 2011
Remove the clutch on a TB525CS trimmer
It is generally CCW. Look on the clutch itself, sometimes there is an arrow covered up in goo.
Sep 27, 2014 | Troy Garden
I have a 42 inch troy-bilt riding mower the blades won't disengage.
Sounds like either the switch for the blades is not shutting off the power to the electric clutch or the clutch itself is not disengaging. I would shut the mower off and unplug the wire to the electric clutch and then start the mower and make sure the blades do not turn you may have the belt for the blades on the wrong pulley and it might be causing the blades to turn. Hope this helps.
Apr 18, 2014 | Troy -Bilt String Trimmer/Blower...
I need to know what kind of oil to put in my troy-bilt 4 cycle weed eater. I think the model num. is TB525CS, it's on the front of the weed eater right under 4 cycle.
Hi jo6616...
Use a good grade of 10W30 non-detergent oil in your weedeater.
Free answer....Please take time to rate me
May 30, 2011 | Troy Garden
How to change trimmer ine in tb525cs - troy built 4 cycle trimmer
Jun 21, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
What size string do i need it is a tb525cs
Probably .065 to 080 line will probably do the trick .A line with 3 or 4 edges works great on everything
Oct 21, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt TB525CS Line Keeps Being Sucked into Housing
You may have wound the line in the wrong direction. Check it out. We all do it at least once...Lee
Sep 09, 2009 | Garden
The starter line on my trimmer will not pull at all.
Remove spark plug to see if problem is in engine or drive unit
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
133 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
