Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Our Toshiba Regza won't turn on. It's plugged in, but when we try to turn it on, the yellow light just blinks & blinks.
    Scholar:
  • 87 Answers
Not my solution but a copy from another problem.  Rate me  =]
"The problem is with the signal board. Basically, it is not allowing the power signal to go from the on button from the set or the remote to the TV. I am having the exact same problem with my 42" LCD Regza. Currently, if you are under warranty, Toshiba does not have these in stock. They will not have them available to send until early January. My TV has been at the repair shop since December 4th. I am very upset as I won't be able to watch the bowl games in HD. If your set is still under warranty then call Toshiba help line at 800-575-5469. You will need the model number of yout TV that is listed on the front of the owner's manual. They are:
27HL67
32HL67
32HL67U
37HL67
42HL67
The first number will be the giveaway as to which model you have. It is the size of your set. They will ask you to try a hard reset. (Hold pwer button down for 5 seconds until you see the yellow light go solid and go off.) This will most likely not work. If it does, you are lucky. I found that if you unplug the TV for an extened period of time, ie overnight, ity may come back on. It will eventually give out completely though. Better to get the problem addressed with the manufacturer. If you are not under warranty then I do not know what to tell you. Right now I am searching the internet to see if I can find this part to maybe purchase myself. Only if it is not too costly. If I find anything I will post here for all. If you have any questions, feel free to email me a wkjtx@hotmail.com and I might be able to give you more details on your problem. Good Luck.
WJ"
Quoted From
http://www.fixya.com/support/t1070173-yellow_light_blinking_blank_screen_turn
Nick
Posted on Sep 03, 2009
Down load this firmware file p/n 2007SEN069 from this address http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=26hl67. The instructions are here also. Un zip to a blank sd card. I'm not sure if the set will boot to the card or not.
I finally got the tv to boot by constantly plugging in the a/c power and unplugging the power until it filally booted and was able to turn the set on.
Remove the sd slot cover from the lower right rear of the set, and insert the sd card with the unzipped firmware. Monitor the screen and follow instructions. Do not remove the card until the set powers off.
This fixed mine, hope others benefit from this repair.
David
Posted on Jun 28, 2010
  • tacr1 Jun 28, 2010
    This link has two firmware options. I used the p/n JL07FW1C as it was smaller. It worked.
Toshiba regza 42rv535u not working, has blinking yellow light, light blinks 3 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 15, 2014 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Toshiba 46 inch regza1080p wont turn on. it clicks,yellow blinking light at front
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 28, 2014 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
My Toshiba regza television won't turn on
A model number would be helpful but in general if the red light just blinks the set is in shutdown since some error or problem has been detected.
Jun 03, 2012 | Televison & Video
Had my toshiba regza 42rv530u since March 2009 a few days ago it cut off and will not come back on, the yellow light flashes at the bottom of the tv, 3 blinks pause 3 blinks etc....
try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
May 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Wont turn on but yellow light is flashing
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Jul 23, 2010 | Toshiba REGZA 47HL167 TV
42hl67 has a continuous blinking yellow light in 3 blink intervals, how do I fix this?
May 09, 2010 | Toshiba 42HL67 42 in. LCD Television
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
TV will not turn on Yellow power ind. Light blinks three times...
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
TV does not turn on. There is a yellow blinking LED light on the right lower corner of the TV
Disconnect your TV. for few minutes (10) then plug it back on, turn it on using your remote control, wait few seconds, until the light bulb gets its normal intensity, if you can not see anything, but there was a clicking noise,then you bulb it's burn out
Dec 23, 2009 | Toshiba REGZA 47HL167 TV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
3,303 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
