Just bought a Belkin N+ Wireless Router when installing it ask to add a Interne provider but Hughes net is not listed on there CD to pick.Then it says if not listed click here did that and it gave me things like PPPoE and so on any suggestions
    Scholar:
  • 122 Answers
If a PC works when directly connected to the sat modem then look at the settings on your network card and plug in the same info to the router. Good Luck
Posted on Sep 03, 2009
I bought a belkin wireless G Plus MIMO router but the cD was not in the box
. You do not have to use the cd.
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 05, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I bought a Belkin N Wireless Router F5D8236-4 v2 and changed my internet provider a few months later and I have lost the Installation CD, can I install it without the CD?
Yes you simply need to hook up via an Ethernet cable, open a browser type in the routers address, login with username and password, and then you can edit any setting you like. Then when finished you save settings and reboot router.
installation guide below.
en-us-support.belkin.com/app/answers/detail/a_id/2533
Aug 12, 2010 | Computers & Internet
Installation of belkin router failed
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
May 08, 2010 | Belkin (F5D5231-4) Router
Hughes net hn9000 I lose connection when I try accessing Inter.
Try to upgrade the firmware of the router.
After upgrading the firmware, reset the router and reconfigure the router.
Click Here for more info
Dec 31, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Belkin f5d7632uk4a v4
hi dear
1. Try and uninstall the Belkin client software
2. Check to see if the WZCSVC service is running
You can check this by issuing the following command:
a) net start
b) sc query wzcsvc
Both command should list some info about WZCSVC (Wireless Zero
Configuration) if it is running.
3. If your wireless card is installed successfully, you should see a
antenna-type icon in the system tray.
If not, you need to install the drivers for the card manually. Check
the Belkin CD for drivers.
4. If you can see your new router's SSID (wireless name) then you should be
able to see it as a non-admin as well.
5. Failing all of this, retry the Belkin client software and its
documentation for indication on non-admin issues or ways to use the above
mentioned Windows wireless client.
oke
Mar 18, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
