Question about Sony Playstation 3 (PS3) Console
PS3 does not detect controller even with a USB cable
I bought a brand new PS3 and when I started it for the first time, it did not detect the controllers, even with USB. I tried changing the controllers and cable, but still it does not work. The screen keeps on asking me to connect controller using a PS3. My PS3 model is CECHL01.
    Problem Solver:
  • 12 Answers
Hold down the ps button. and then connect a usb cable .
Posted on Sep 04, 2009
Sony play 3 wirerless controller brand new turn it on and just four lights blink?for about 3 minutes then shuts off
Hi there. To fix this you will need to register your new controller with your PS3.
Do the following:
Connect your New PS3 controller to the PS3 with the USB cable. Followed by the PS button on the new controller. This should send the driver to the PS3 so that it recognizes that you have a new controller.
Apr 15, 2011 | Sony Wireless Controller for PlayStation 3
My ps3 controller can't turn on even i use the usb cable..the red light didn't blink at all..i try push the PS button still no effect..it just happen after play the game n want to eject the cd n...
Have you tried hitting the reset button on the controller? While it's plugged in via USB, get something small and hit the reset button on the back. (Right next to the front and center screw)
Sep 11, 2010 | Sony Wireless Controller for PS3
Just bought an older 80 gig ps3 from a pawn shop. I received hdmi, power audio and video cable, and 1 wireless controller with usb cord. when I power up the unit it says detected an hdmi source.. but I...
you need to plug the usb cord in to the ps3 and the controller. then press the ps button then it should work. if it does not then keep it plugged in and press the small reset button with a pin on the back of the controller and then repeat the first step.
Jun 08, 2010 | Sony Playstation 3 (PS3) Console
I cant get my controller to program to my ps3 we just bought it at gamestop and when we plug it in to the ps3 and try to program it the center button just keeps on lighting up and flashing
Normally, any time you push the PS button on the sixaxis, and it's NOT synced, it should always go into syncing mode where you see the lights start to flash. All sixaxises should work like this. If you happen to have a ds3 it might work different, I don't know about those.
It's possible that it may not be charged up enough to do the syncing wirelessly, even though it can send the start-up signal. Try experimenting by charging it up fully, then seeing if it will start and auto-sync.
After you connect the usb cable and it syncs, can you disconnect the cable, and have the controller still work? If not, I would suspect a defective or loose battery, which can be easily fixed by opening the controller and securing the battery wire's connector plug, or replacing it.
If it will still work after you re-detach the usb cable, it sounds more like some defect in the controller itself. Could be you would need a new one to fix it.
Nov 29, 2009 | Video Game Consoles & Games
PS3 Dualshock Does not Charge.
hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
May 10, 2009 | Sony Dual Shock 3 Controller for...
My ps3 wont recognize my dual shock controller
You just need to connect the controller to the PS3 with the USB cable and it will fix the problem!
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Dec 10, 2007 | Sony Playstation 3 (PS3) Console
Ps3 controller
I was having the same problem. Controller would only work when plugged in.
Solution: I shut down and unplugged the PS3 for several minutes. Plugged in the controller. Turned on the PS3 and let it boot up. Pressed the PS button on the controller and let it sink up. When I unplugged the controller it worked.
Nov 18, 2007 | Sony Playstation 3 (PS3) Console
PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
Oct 16, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,657 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
