I have an 2 zone outdoor unit. 2x 9000 btu Aura indoor units. Both on 16ft lines. When i installed the first indoor unit and ran the setup the system would shut down every few mins and then restart after a while. Error code P6 would flash and the run and timer lights would alternate. First assumed a defective compressor or so but after hooking up 2nd unit it went away. Seems that hooking Both units up to a 2 zone is required otherwise the compressor sends a fault code P6.
Our 24000 BTU indoor unit goes on Kom every 10-15 Min. It is not right. The technical guy was here now 6 day and can't find the problem. Can you help 0737348993
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
I can guide you as long we can chat > so i can guide step by step instructions. 1.prepare your formatted ( NTFS file system,faster than FAT file system ) flash drive 2gb or more 2.Full copy Operating sytem eg.windows xp. 3.On the other unit eg.cpu plug your flash drive 4.disable your anti virus ( works faster without it ) 5.....
Check the thermostat, does it open and close (electrically)?
In the past three years, has the unit been cleaned? If the coil is plugged with dust, there may have been serious damage to the comressor.
With the unit unplugged, using a multi-meter, is there continuity between the switch hot tab and the compressor feed?
Is there a run capacitor on the compressor? If so, is it shorted or open?
These will give you a few places to start. If you do not know how to operate a multimeter, you need a contractor. Another option is to check your phone book and look for an local refrigeration school. Often, these schools will do the repairs if you pay for the parts.
