Question about Sony Handycam DCR-TRV103 Digital Camcorder
Tape deck won't close after tape inserted sony dcr-trv103 r
Tape deck won't close after tape inserted/ when I use Eject button, case opens and closes properly. When I insert tape, I close the front and there are wheels spinning below and the deck won't go back down
  • me1818 Sep 03, 2009
    there is a flashing yellow triangle in the middle of the lcd screen a a flashing c:31:40
    Sniper:
  • 92 Answers
  • 10,594 Answers
Do you see any error code flashing at top right in camcorder LCD?
Let me know that error code please.
Posted on Sep 03, 2009
  • Shahid Electronics
    Shahid Electronics Sep 03, 2009
    OK, C:31:40 shows problem with video head motor (drum assembly)
    If you are comfortable with below repair tip, go ahead or take camcorder to local camera repair shop for fix...
    First observe does head motor spins when you close tape door with tape?
    If no, some thing is stopping head that can be mechanical part or head motor does not get power volts to spin. Camcorder needs to be apart to find out what thing is being abstracting head motor.
    Thanks.
How do I load the tape
I see your picture of a cassette player. Guess you are referring to that. (tapes also come in reel-to-reel, and 8-track). Just push the "EJECT" button (power may need to be applied to some units for the eject button to work). The tape slot will open. Insert tape with exposed tape on the "head" side of the opening, usually the heads are on the bottom of the slot.. You can't put it in any other way and have the door close. The "door" that opens has guides for you to slide the tape into. The side you want to listen to should face you. Either manually close the tape compartment or push the close button (depending on model). If the door doesn't close, you put it in upside down. Push play and enjoy.
Oct 01, 2014 | Audio Players & Recorders
Tape stuck, Mechanically Eject
Try staring up the camera while hitting the rewind button
Oct 29, 2013 | Sony Handycam DCR-TRV520 Digital Camcorder
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Sony DCR-PC101E tape will not eject
Paid for someone to fix it! They said the motor wasn't working
May 19, 2008 | Video Cameras
"Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Aug 22, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam DCR-TRV103 Digital Camcorder Logo
898 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
