Question about Sun Pure SP-20 Air Purifier
I paid yesterdAY and I bought a new fuse but that doesn't make it turn on. If the air filters are taken out should the machine still turn on if the back is off? Or do I have to put everything back together to try to turn it on?
  • 3 more comments
  • rgsachs Sep 03, 2009
    The model number is SP-20 and it is a Sun Pure
    What are you talking about--this is not a water purifyer--this is an air cleaner with a hepa filter and a pre filter and an ultraviolet light. I have no idea what a floater switch is
    I will try this. Please wait a bit for me to reply
    Thank you
    Bobbi Sachs
    Bravo ! It works! I am a 70 year old Lady and I am so proud that I could make this happen without calling in a special serviceman! Thank you thank you thank you!
    Roberta Sachs
    I am so appreciative. Thank you so much!
  • 612 Answers
There may be a switch that opens when you remove the filter, but I have never seen one that had one. If you can give me the make and model number of the unit, I can be alot more help.
Posted on Sep 03, 2009
  • 2 more comments
  • James Hilton
    James Hilton Sep 03, 2009
    There is not a switch that cut unit off when filter is removed. The only switch that is line with the motor other than the on/off is the float switch. It turns the unit off when the tank if full of water. It would also not let unit run if it were tilted over enough that the float switch was in the full position. You have replaced the fuse. Now make sure the unit is sitting upright, look at the float switch and be sure it's in the down position. Turn the unit on, the unit should now run unless you have so other problem. I show that there is nothing else in the line between the motor and the switch other than these. Switch,fuse, float switch, fan motor.
    Please rate solution
  • James Hilton
    Please rate solution. Thanks
  • James Hilton
    My picture shows it was a de-humitifier. This was my mistake. Sorry I keyed in the wrong number orsomething. I'll look again/
  • James Hilton
    Sorry. I found it. Here is your answer. Both the top and front grill have safety interlocks that will turn the unit off if removed while in operation. If either grill is not properly closed the unit will not operate. Make sure the top grill is completely snapped into place and the front grill is completely secured at the bottom before turning the unit on again.
    Please rate this solution
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
My Fresh Air Eqo Quest shut off yesterday and I can't get it to go back on. I have hit the reset button, I unplugged and replugged, I even cleaned everything. It won't turn back on. Is there a...
There is a fuse in where the AC cord plugs into the purifier. Remove the back cover, and you should be able to remove the fuse by prying the fuse cover off with at straight screwdriver. It takes a 1.6 amp fuse for 120Volts
Jun 06, 2011 | Ecoquest Fresh Air Air Purifier
Every time I clean the filter and the plate the ozone doesn't come on. I usually can fiddle with it and it will come on, but this time it didn't. What am I doing wrong and how can I fix it? this...
The plate is going bad. Sometimes it's just a bad part of the plate that has corrosion under it, try turning the plate and sliding in again. Sometimes that's all it needs. Sometimes it just needs to be brushed well, cleaned, and then blow-dried.
May 30, 2011 | Ecoquest Living Air Classic Air Purifier
Yesterday, I purchased a new RCI filter and replaced it and the light of the new filter does not light when turned on and the machine says replace RCI filter as it did when it quit working..Thanks.
Perhaps, the tab on the filter frame, that triggers the safety switch is not making contact. Remove the filter and reinstall the filter. Make sure you push the tab firmly into the trigger slot. That should solve your problem. Please let me know.
Mar 17, 2011 | Ecoquest Fresh Air Air Purifier
I have no power to my Fresh Air by Ecoquest. I've taken it apart and all connections seem to be in place. Still nothing when pushing the reset or power buttons. Any advice?
Remove the filter on the back. On the outer edge of the filter frame, you will see a plastic tab. This tab is a safety switch and if it's not making proper contact with the trigger of the unit, it will not power up. Push the tab section of the filter frame snugly in first and then the remainder of the filter frame. That should solve your problem. It that doesn't solve the problem, check for a blown fuse, The fuse holder is on the back of the unit.
Mar 14, 2011 | Ecoquest Fresh Air Air Purifier
I lost neutral on the electrical service and my cleaner no longer works, i changed the fuse that had blown, but when i turned the filter on it simply blew the new fuse
Blowing a new fuse would indicate that there is some component of the machine which was damaged. The fuse is a safety device which keeps electricity from flowing through defective wiring.
You can visually inspect the machine to see if there are any wires, connections, or components that appear to be damaged, burned, loose, or broken. The plates need to be perfect, without cracks, burned spots, loose mucilage, broken screens, etc. The contact fingers should be screwed firmly in place, and they should press firmly against the screen part of the plate.
If you can detect and then repair any of the above defects, and if the machine still blows the fuse, you can assume that the problem is deeper in the machine and it needs professional help! Unfortunately, Vollara (formerly EcoQuest) no longer makes or repairs the Flair. You can contact Vollara customer service 800-989-2299 to locate a dealer in your area; they may have another machine or know where you could get one. They may also know of someone who could repair it for you.
Jan 12, 2011 | Ecoquest Flair Air Purifier
I'm 79 yrs old. I think I got taken advantage of by a fast talking salesman and paid way too much for my Defender air cleaner. I didn't get a manual, and i don't know how or when to change the filter....
Schedule: Remember, to receive the full benefit from your Defender® , replace your filters regularly. • Every 6 months, replace your Enviropure® Charcoal Filter. • Once a year (for Perpetual Warranty*)/up to every 3 years (depending on usage), replace your Medi-Filter® Cartridge.
Filters available from this Amazon seller: http://www.amazon.com/gp/search/ref=sr_in_-2_p_4_19?me=A2XHGJAEAIWR55&rh=i:merchant-items,n:!1063498,p_4:Filter+Queen&bbn=1063498&ie=UTF8&qid=1293951284&rnid=15899471
PDF manual here:
http://www.filterqueen.com/pdf/defender.pdf
Dec 20, 2010 | Filter Queen Defender Air Purifier
I HAVE THE LIVING AIR XL 15C
Check the fuse. You may need a new one.
Jul 22, 2009 | Alpine Air XL-15 Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Sun Pure SP-20 Air Purifier Logo
Top Sun Pure Air Purifiers Experts
Are you a Sun Pure Air Purifier Expert? Answer questions, earn points and help others
