Question about Ovens
Stove uneven heat in the oven back much hotter than front area
  • deer929 Dec 07, 2007
    it is a problem with the oven the rear of the oven gets much hotter than the front of the oven
  • 833 Answers
Electric or gas? Is it clean and not lined with foil? If gas, does the flame all look blue along the burner length? If electric, how many elements are there? Do they all glow in the area where you expect them to when the unit is heating? Where are they? Answering these questions should lead to a solution.
Posted on Dec 07, 2007
Oven only heats to 215 degrees will not get any hotter.
Sounds like the heat sensor is bad. I'm assuming this is an electric oven. On the inside back wall of the oven you will see a metal rod sticking out. Unplug the stove, take off the back cover and you'll see where it's attached. Unscrew the keeper and pull it out through the back. Unplug it from the wiring harness.
Apr 15, 2012 | Ovens
My Maytag stove. I know it's normal to feel heat from the vent on the stove top when the oven is on. But the temp of the heat escaping is sooo much hotter than it used to be. Do I need a fix ? Model...
The heat from your vent should be a little lower than what the oven is set at. So I doubt if you have a problem but you might want to take some temperature measurements to see.
Sep 07, 2011 | Ovens
Oven heats to about 250 and doesn't get any hotter, stove burners work fine.
Very likely you have a faulty oven sensor, and need to replace it. They are not very expensive, and are easy to replace. The oven sensor monitors the oven temp, and "tells" the element when to cycle.
Oct 14, 2009 | Ovens
Oven hotter at the back
You should always preheat oven to operating temperature before cooking anything.
Do not put too much in oven, leave plenty af space for good air circulation.
Do not place any reflective foil or the like on the bottom of oven or shelves, as this reflects heat, and you will get uneven cooking.
Make sure fan is working efficiently if it is fan assisted.
Dec 09, 2008 | Neff U1421 Double circotherm Electric Oven
Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
May 01, 2008 | Stoves 720EF Electric Double Oven
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
80 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
