Question about Sony Ericsson Walkman W810i Cellular Phone
Charging problem unable to charge the battery on my w810i Sony Ericsson ! phone works perfectly when a fully charged battery into it, been told its a software problem ? can this be put right economically or would i be best replacing it for another phone ???????
My sony ericsson w810i phone is not charging through charger but is charging with data cable. The charging jack has been recently replaced. What is the solution for this?
sony ericsson phones have their own two-prong charger/data plug. You will need to purchase another AC charger, or you can purchase a plug that has a female USB and use that. Good luck!
Nov 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
Sony ericsson w810i
First check your battery whether it is fully charged.And also check your memory card whether it has any virus in it.Because virus in memory card will also cause this problem.Don't forget to check your battery
Aug 05, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Screen Wont turn on, only power.
you should have charged it for 4-6 hours,try using a different battery if you think you have charged it fully.new cellphones requires longer time to be charged
Jun 26, 2008 | Sony Ericsson Walkman W810i Cellular Phone
White screen
i got the say problem 2 days back. I read some pots in forums. This is what worked for me. First fully charge the phone some. Get a friend's phone or something. Then get ready with the data cable and your computer with internet.
Goto Sony ericsson site.
search for w810i SEUS Sonys update system.
At the bottom result it says"Sony Ericsson - Support - Update Service Compatible with K510i W810i W200i .
Click on that and dowload the program. At the right corner it shows the phones which supports it.
install the program and run it.
do exactly what it says.
It worked for me. I got all my contacts and messages back.
Good luck
-Manoj
May 18, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson w810i
Good luck
-Manoj
May 07, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Battery charge is not lasting
If your connection to the Internet service is ON for long perods of time, not necessarily used, it will run the phone battery down. If your battery doesn't keep its charge its time to replace it. Use only the Sony Ericsson Battery recommended for your phone, not a similar battery.
Feb 08, 2008 | Sony Ericsson Walkman W810i Cellular Phone
W810i doesnt turn on or connect via usb
Charge the phone until it has finished charging, The first thing to do is to make sure that the phone is charged. Attach the charger and charge the phone for about 2.5 hours. Please note that the battery icon may not appear until after the phone has charged for 30 minutes. When the battery icon has stopped “flashing” the phone is fully charged.
Jan 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony ericcson w810i
Brother it seems your phone's software problem. Such problem can be occured due to removal of battery in it's active mode or use the phone in less charged battery. Solution is to reflash it with new files...Any good technician with understandign of sony-erric's CID security and nice tools like Universal Box, SE TOOL can do this for you but he will charge you for that. It is not possible to do anything without tools, tools and rather costly.
Jan 11, 2008 | Sony Ericsson Walkman W810i Cellular Phone
My W810i keeps flashing on and off,unable to use it.
first of all check if the battery is fully charged or not. If it does not solve the problem then you might have to reload the software by using UFX box. For that you have to go to the Sony Ericsson service or any Mobile repairng shop.
Nov 18, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Song ericsson w810i flashing screen
how do i reprogram the phone? i have the same problem but dont know how to reprogram it....help :)
Aug 24, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
43 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
