Question about Kenmore 22812 Bagged Canister Vacuum
Indicator block has broken twice - Kenmore 22812 Bagged Canister Vacuum
  • 430 Answers
If you are referring to the bag fill indicator this is a common occurrence and many mid to low range vacs.It may begin to stick as dirt build s inside. You could try using a multi ply filter bag for less dust leakage
Posted on Sep 06, 2009
How do i repair a hoover elite rewind broken belt?
You can't repair the belt. It must be replaced. A new belt must be stretched to almost twice their original length to be installed. They will lose elasticity and should be replaced at least twice per year for proper cleaning of carpets.
Apr 27, 2014 | Hoover Vacuums
My neato is showing a message 'my vision was blocked. Please press ok (3000)'. How do I fix this?
Dust off your drop sensors. Using a cotton swab, clean the two drop
sensor windows on the bottom of your Neato Vacuum. Power cycle the unit, removing the batteries if necessary. You should be good to go.
Sep 20, 2013 | Neato Vacuums
I have the ultimate G The belt is on, new bag, vacuum runs but no roller rotation and minimal if any suction????
On the right side of your vacuum head, there is a green belt indicator light. If when the unit is powered on and this light is not lighting up, you have a broken belt, or you didnt properly latch the belt in place.
a) Broken belt- you can use the belt from your shampoo'er if you have one, otherwise your nearest Kirby distributor has them for a couple bucks
b) As for the suction, the Kirby has 2 motors. 1 motor is for the cleaning of the floor, the other motor (where you see the vent on the left side) is for keeping the unit cool to expand the life, which btw average life of a kirby is 20yrs and they all come with a lifetime refurbishing plan. If your not getting any suction check the boot of the bag where it hooks onto the unit for any clogging
Jan 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Will not vacuum up the water
I assume the switch on the base it set to floor and not tools, and that when you remove the tank, the rectangular screen is not totally blocked with lint, etc., and that there is no other obvious clogging, and also that the lid on the unit is seated properly, as well as checking the float to see if it is stuck, since the float cuts off suction when the tank is full.
Check your belts (see manual) to see if the pump belt is broken. There is an access door on the side of the base unit - you need a flat head screw driver to pop off the cover. I have replaced mine twice and keep a spare handy.
I did have to take a previous bissell machine to the repair shop and pay to have the pump motor replaced.
Aug 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Power Steamer Pro
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Will not dispence any liquid
i have the same problem. But my pump belt is broken. Ive oredered a new one so hope to receive that in few days. Not sure if it is linked though
Aug 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
No water or soap coming out
the filter could be block under the flow indicator cap,
but water should still come out of the hose
Nov 07, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Kenmore 22812 Bagged Canister Vacuum Logo
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
