Question about Logitech Cordless Mouse
How to open its little guts to change the battery?
    President:
  • 3,278 Answers
The upper portion of the case, behind the buttons, should slide back to reveal the battery compartment.
Hope this helps.
Posted on Sep 03, 2009
My belt turned in to red and in engine its making little extra sound and i think its in motor. Do you think i need to change my belt?
If u gut 75thou on it...belts dont last like chains..no quic starts for now. Also change water pump and guides to save$
Nov 08, 2015 | 2007 Nissan Altima 2.5
Why does the front passenger door intermittently not open from either the inside or the outside and then all of a sudden it will work for a few days.
Door latch guts are worn. On newer cars they tend to be made of plastic and wear down. Get a Chilton/Haynes repair manual for your little BowTie and it will explain and show you how to replace the guts. Do it before it fails entirely. Other wise you're stuck trying to take inside door panels off when the door is closed.
Mar 07, 2015 | 2006 Chevrolet Cobalt
Koto the dinosaur doesn't work
You have 45 days to file a dispute with eBay. After that, unless you used a credit card, you're stuck with it. If you're within the 45 days, go to the Resolution Center on eBay and file a dispute. If the seller responds with a *tough luck* answer, immediately escalate to a claim and indicate that the seller failed to disclose the corroded batteries and damaged battery case. I'm not sure what you mean when you say your little girl is gutted, but that's not really relevant. You will have to bear the expense of sending it back - ship parcel post with delivery confirmation. If you buy your postage online, it's cheaper. Good luck :)
Jan 03, 2012 | Hasbro Toys
When started makes sound but no water flows in. Hose looks ok
The most comon problem is a water input valve that gets plugged or the input strainer. The valve uses a tiny pintle pulled by a solenoid that opens a small orifice which then moves a diaphram that opens the main valve seat. A small piece of contamination can plug the little orifice so valve won't open. USUALLY you can take valve out and clean the little screen where the water comes in and disassemble and clean the guts of the valve. Be careful to NOT lose the little spring behind the pintle.
Oct 29, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
On the bottom of the camera there is the area where you slide open and put the batteries in. The little "door" that slides open broke apart and I can't keep the door closed. Can you buy that...
I doubt it, but you could just tape it shut. You might contact Kodak but like I said, not much change for a part like that, you might be able to purchase the case but pretty expensive and probaby very difficult to install the guts into. if you have all the parts to the door, you might be able to glue it back together.
Mar 11, 2011 | Kodak Easyshare C813 Digital Camera
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
Ryobi 18v battery drill/driver on/off switch faulty stuck on go
if the trigger won't pop out it will need to be changed. tool parts direct or ereplacement parts are good to find parts. be very careful if or when you open the case. when the guts come out they go back one way or the case won't close.
Aug 28, 2010 | Ryobi 18v Variable Speed Impact Driver...
Garmin Forerunner 50 Battery Replacement
Thanks MarcS_Ca - I've supplemented what you offer with some photographs at
http://gnjmch.com/public/tips/GarminF50.Battery.html
Aug 30, 2008 | Garmin Forerunner 50
How do I release the battery clip on a Timex Expedition watch to change the battery.
I just had this problem, and my 8 year old and I had to fiddle a bit to figure it out.
Just to confirm, you have removed the back cover and taken the watch guts out of the face and strap assembly and are looking at the battery which has a cover over it and maybe a sticker on the cover that says "unlatch to remove battery", with two >'s, one pointing to to each side?
On each side there are two small metal tabs, which surround a small moulded-in plastic piece with an opening in the middle.
The release is in that opening in the plastic piece. You need to fish around in that opening a little to catch the release and push it outward toward the edge of the watch (away from the battery). You need something very small to do this with, like a straight pin. If successful, the cover pops up on one side and then you do the same on the other side.
Good luck.
Jul 20, 2008 | Timex Watches
Ground clip on H10 - 20 GB MP3 Player
No diagrams available - there is no component level support for IRiver - you opened it and actually saw the guts so you know more than 90% of us - good luck with that
Oct 23, 2007 | iRiver H10 MP3 Player
Logitech Cordless Mouse Logo
21 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
