I have a Kenmore 80 Series washer that started leaking just a little a few weeks ago. Checked all the exterior hoses and they are fine. Today it leaked worse. It appears to be coming from the front not the back of the machine.
  • 30 Answers
You have a hole in the water pump.
You need to remove the control panel.
Locate two gold clips, one on each side of the unit.
Remove clips, open the lid and pull the cabinet toward you. Water pump is right in front at the bottom.
Posted on Sep 03, 2009
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
My washing machine will do nothing when you pull the knob to start it. I checked it is plugged in. It is a kenmore series 80. this washer is a great washer but it is probably 12or 13 years ago. i...
hi there........most likley a faulty door switch is causing your problem.....replace the door switch and all should be fine again
regards Sir Galahad
Aug 16, 2009 | Washing Machines
Leaking water
Your pump is leaking. it is attached to the front of the motor. Very common. Pump retails around $60.
Part number is 3363394
May 19, 2009 | Kenmore Washing Machines
Kenmore 80 series
check for corrosion or cracks on the outer tub.that might be the only problem.good luck.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series leaving soap behind
check for clogs in the output line (the drain hose)
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer
Sounds like you need a mixing valve.
double check for water from the source.
Jun 04, 2008 | Washing Machines
Kenmore 80 series leaking
the pump is most likely the cause if you have mach skills i can walk you thru it on how to open the unit and check it let me know
Jan 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
I'm having the same exact problem, you posted this issue in Oct, have you found a fix?
Oct 18, 2006 | Kenmore 24902 Top Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
