This is a fuser error, you can try unplugging the machine and plugging it back in and this might reset the error, however if you try this and the error code pops up again, it could be one of the following which would require having the machine serviced and repaired by a professional. The fuser thermistor could be open or the heater lamp could be open or the thermal fuse that prevents the fuser from overheating could be open.
The print is light and there is a 1 inch fade that runs across the page vertically. All toners are...
(More)
The print is light and there is a 1 inch fade that runs across the page vertically. All toners are brand new.
something came through by fax and it is stuck in memory. It says change paper size cassette A4. ...
(More)
something came through by fax and it is stuck in memory. It says change paper size cassette A4. How do I get rid of it?
I need to know how to use the bypass feature. Pictures would help. I want to use photo paper. Is...
(More)
I need to know how to use the bypass feature. Pictures would help. I want to use photo paper. Is this possible?
I am able to send fax but not receive. When a fax is coming in the phone does a slight ring and then...
(More)
I am able to send fax but not receive. When a fax is coming in the phone does a slight ring and then cuts off.
