Question about Food Mixers
My mixer runs but is not transfering power to the planitary
    Problem Solver:
  • 10 Answers
Basically you're saying that it won't give power to the spinner?
What I was thinking is that there is a internal wire broken inside the machine so you'll have to make a complaint and get a replacement.
Posted on Sep 03, 2009
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
How do you take apart the KitchenAid Mixer K5SS to get at the gears? The motor runs but the beater doesn't go around. I have an exploded view, but it isn't clear how to begin disassembling the planetary.
It quick terms, first remove the head. Take off the band, this is where the two halves join. Undo any screws holding the halves together. Remove the pin holding the planetary in place. Remove the trim disc. The planetary assembly lifts out but you may need to work around it carefully lifting it a little at a time.
Sep 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Not all speeds working just speed 3
check keys on all shafts and bottom planitary nuts tight Hobart keeps there service manuals to themselves. also you need to know the version you have. they have been out over 45 years and many changes
Sep 13, 2008 | Hobart A200 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Sound like bearings
Ist check your agitator shaft for looseness. the shaft you put the beater on. wiggle side to side. if tight no play. If in first its quiet but you can here a grumble under load but second gets louder. and third even louder. If the shaft is tight. your gears down there are warn. you can take that all off with the two nuts underneath. and check the grease on the gears but even with new grease on them it most likely stay loud. grease it with hobart grease from your loacal hobart for the A-200 planitary not the transmision they also fve grease for Trans. if you can take the noise run it that way if not decide which arm & leg you want to give hobart for new gears.
A200T mixer
On the bottom of the planitary the part where you put the beater. there is two nuts. one lookes like a Acorn nut and a thin one above it. By the book the top thin one should be finger tight. Not wrench tight. you need a thin wall 3/4" wrench you hold the thin nut with iot and tighten up the bottom acorn up to the thin one and they lack against each other so not to come losse .on some mixers this thin nut tightend down will mess with older parts and bind the centersahft parts.
Aug 14, 2008 | Hobart A200 Stand Mixer
Kitchen aid mixer
the unit sounds like the drive unit is stripped. if the planitary unit is spinning that gear is ok but the one below that is stripped. which is the one that spins the beater. Usually the professional lines are covered under a 2 year warranty. where as the others are a 1 year. I would contact kitchenaid first and see if your product is covered for replacement. they are really good about replacing faulty units. if not the unit can be repaired. It is a simple process and you can buy the parts off kitchenaid. usually the parts come with instructions as to how to replace them but if not repost to me and ill get you the directions on how to replace it.
May 07, 2008 | Food Mixers
Metal stem broke!
you should be able to order the part from kitchenaid.com. while you replace the stem it might be a good idea to replace the hub, and the gear assembly in the planitary unit
Feb 12, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
