Question about Adobe Acrobat 6.0 Professional for PC
Adobe Acrobat 6.0
Hello: When I try and open a pdf file on websites, I get error message and get shut down. Can you help? Miguel in San Diego
  • Anonymous Feb 11, 2008
    I was using Adobe Reader 6.0. I never could get Adobe 7 or 8 to work before. Somehow, my computer downloaded 8.1 without my known authorization and I lost 6.0. I can not find my old copy of 6.0. Now i can't get 8.1 to open any of by old pdf files. I just get an error message and nothing happens. How can I get 8.1 to work.
    Problem Solver:
  • 15 Answers
Use foxit reader it is way faster and better than adobe
http://foxit-pdf-reader.softonic.de/
it free!
Posted on Dec 07, 2007
Adobe Reader on ASUS laptop
PDF Repair Toolbox is a a new Adobe Acrobat file repair tool that allows users to fix PDF files which are inpdfible from Adobe's file recovery. A common error message from Adobie is that Acrobat PDF file format is having difficulties, the file is damaged and could not be repaired by normal means.
https://www.acrobatrepairtoolbox.com/
Jun 21, 2018 | ASUS Computers & Internet
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
Is there any way to open an Acrobat 9 file with Adobe Reader 5?
Download the Adobe Reader 9 software. It's free from Adobe.
Mar 01, 2009 | Adobe Acrobat 6.0 for PC
Acrobat 7.1 shuts down after opening
Installing later version of Adobe Acrobat is sometime creating compatibility issue with previous installed Adobe Acrobat Pro.
Make a deep search for your condition on Adobe KB: for similar problem I had to Reinstall Adobe Pro AFTER an update of Reader free Sw.
Check this entry
Dec 29, 2008 | Adobe Acrobat 6.0 Professional for PC
Adobe reader error message
In Internet Explorer, when you click on a link to a pdf file,
you get the error message “Adobe Reader could not open ‘filename.fdf’ because it is either not a supported file type or because the file has been corrupted.”
This error is due to an issue with Adobe Acrobat viewing PDF files in a web browser.
Try the following:
1. Open Internet Explorer, go to Tools -> Internet Options and on the General tab to erase all temporary files, cookies and history data.
2. Under Internet Explorer -> Tools -> Internet Options, on the General tab click on Settings and make sure you select the option “Automatically” for checking for newer versions of the stored pages. Then attempt to open the PDC file again.
3. If solutions 1 and 2 do not work then uninstall Adobe Acrobat, then reinstall it again.
It seems that Acrobat 6 is more prone to this error so upgrading to Acrobat 7 may solve the problem.
All d best.
Any furthur help feel free to ask me again i will be more than happy to assist you.
Dec 22, 2008 | Adobe Acrobat 7.0 for PC
Access to PDF files on email attachments
Try checking the file association. Open the Control Panel, Click on Folder Options, Select the File Types tab, Scroll down to locate the PDF extension, Select the PDF extension, Look below in the Details for PDF extension and select Change, locate and select Adobe Acrobat or Adobe Reader, then make sure there is a check mark in the "Always use the selected program to open this kind of file", Click on OK and then close.
Oct 15, 2008 | Adobe Acrobat 6.0 Professional for PC
Office 2007 professional and Adobe 8 Professional problem
Very simple fix. Now and then after an Adobe Acrobat update Office will disable Adobe Acrobat as it is an add on. All you need to do is re-enable Adobe Acrobat. In Office 2007 goto Word Options, Add-ons, and at the bottom of the page is Manage. Click on the down arrow and select Disabled Items and click on GO. Re-enable Acrobat and you should be fine. In Office 2003, goto Help and selects disabled macros and re-enabler Acrobat.
Feb 25, 2008 | Microsoft Office Professional 2007 Full...
Viewing pdf files on internet
Uninstall Adobe Reader, shut down completely for at least 30 seconds, and then restart.
This releases "Locked files" for deletion.
Then do a search for "Adobe", in 'all files and folders' - search with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those files found.
You should do this search and delete whenever you un-install any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
BEFORE RE-INSTALLING Printmaster
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling. Go to the Adobe website and install the newest Adobe Reader 8.1 program.
http://www.adobe.com/products/acrobat/readstep2.html
Dec 07, 2007 | Adobe Acrobat 6.0 Professional for PC
Adobe Acrobat 6.0 Professional for PC Logo
98 people viewed this question
Top Adobe Computers & Internet Experts
Peter Dragonetti
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
