My printer was jamming paper inside then I cleaned the rollers with rubbing alcohol. Now it goes into an error status as soon as I put the toner cartridge assembly into the printer. How can I fix this problem ? I have a Brother HL-5240 Laser Printer
  • 6 Answers
Roller should not be cleaned with alchol u can clean it with only tissue paper or soft cotton cloth elasticity behaviour may gone so change ur catridge
Posted on Sep 08, 2009
Mfc-9320cw paper jam error yet no real jam want to reset
The most common problem is dirty paper pickup and feed rollers. Try cleaning the rollers with a clean lint-free cloth (not paper towels) moistened (not soaked) with a little distilled water. You can use rubbing alcohol in a pinch, but it tends to make the rubber brittle and crack over time. If the rollers feel very smooth, they may be worn down too much, and you should replace them. Next, look for stuck paper sensor flags. Make sure they move freely. There are a number of them at various points in the paper path. A printer tech will be able to find them all. The printer monitors paper motion with optical sensors. A little dust or toner powder in the optical path can cause a paper jam error. You should call a printer tech for deep cleaning and sensor cleaning.
Nov 20, 2012 | Brother MFC9320CW All-In-One Printer
Printer won't take paper
Regarding the paper not engaging with the Dell 1110 Mono Laser Printer, I previously read somewhere that taking iso-propanol (everyday rubbing alcohol, $1.00 for 24 ounces) and cleaning the centrally-located black roller (located just above the leading-edge of the paper) with a cotton-ball and the alcohol could solve the problem and it did -- My Printer Is WORKING. I was shocked! Actually, I couldn't find our bottle of alcohol, so I substituted with a chemically similar product. I used hand-sanitizer which is about 70% v/v ethyl alcohol -- a similar enough solvent. My Dell 1110 is working like it's brand new. Also, I wasn't able to rub the alcohol on the back side of the roller -- just a logistics problem that I couldn't solve without removing the entire roller. If anyone knows how to remove the rubber roller in 5 or less easy steps, I would love to know.
Mar 07, 2012 | Dell 1110 Laser Printer
Sir! the problem of our kyocera mita fs 3800 is this that it gives us message that the paper is jam please open the cassette 1.and remove the paper. we opened the cassette 1 checked the tray but there is...
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Apr 04, 2011 | Kyocera Mita FS 3800 Laser Printer
Feed jam
1) Be sure the paper tray is inserted all the way in.
2) Be sure you're using the right size of paper (width, length and thickness; paper that is too thick may jam a laser printer if it is not configured properly)
3) Be sure you're using the correct TYPE of paper. Paper designed for ink-jets sometimes produce paper jams on laser printers.
4) If the paper was jammed before, you may have a small piece of paper jammed in the printer rollers. Open the printer and very carefully look for small pieces of paper on the rollers and all the paper paths.
5) Also, some printers are very picky about how much paper you have in your paper trays. Place enough paper on the paper trays so that it is about 3/4 full, no more, no less.
6) The paper rollers that pick up the paper may be dirty with dust. Use a q-tip and 2 drops of rubbing alcohol to wipe the rollers clean. Rotate the rollers with your fingers to be sure that all the surface of the rollers are wiped clean. Be sure to use 91 % rubbing alcohol; carefully read the label of the alcohol and use the one that DOES NOT contain anything except rubbing or isopropyl alcohol and water, no glycerin or any other additives. Wait at least 1 hr before using the printer again to be sure that the alcohol has completely evaportaed .
Please, report back if you need further assistance.
Mar 31, 2010 | Samsung CLP 315 Laser Printer
Paper jams, remove toner put it back then restart printer!
May be the rubber rollers are coated with dust
Clean it and try after it dries.
(Plz do not use 70grammes papers)...use 80g
Feb 06, 2010 | Brother HL-2070N Laser Printer
Printer says paper jam when there is no paper jam hit the ok button and it will print out a paer fine and then say paper jam again. repeat
the rollers that feed the paper into the machine have a a set time limit to do so... if the rollers cann't do it in this time limit then you get a paper jam. you either need to clean the rollers with isopropyl alcohol (rubbing alcohol ) and a rag or replace the rollers...
Dec 29, 2009 | Lexmark T644 Laser Printer
Consistently get a paper jam error when I go to print on my Lexmark OptraC710
sounds like you need to clean the feed rollers that feed paper into machine with clean rag and isopropyl alcohol (rubbing alcohol) and/or looking for any paper jammed in machine...
Dec 27, 2009 | Lexmark Optra C710 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Reload printer error
Try removing the paper tray, and look under where the paper goes. You should see a rubber pick up roller. Try cleaning it with a rag and some rubbing alcohol. The roller is probably slipping and not carrying the paper in far enough! Good luck John
Jul 10, 2007 | Brother MFC-5840CN All-In-One InkJet...
Dell 1700n Jamming
try "rotating the pick up tires". (dell tech's phrase, not mine). pull the paper tray clear out of cabinet and look up inside the bottom of the printer. you will see a t shaped assembly with 2 large rubber tires (rollers). pull the assembly down (spring loaded) and peel the tires off the plastic mounting rollers. turn the tires inside out and replace them.
Feb 20, 2007 | Dell 1700n Laser Printer
133 people viewed this question
jasbo
jasbo
