Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Pro Cut II
When should I use the pro cut II head as opposed to the regular head
3 Suggested Answers
boscia
  • 163 Answers
SOURCE: fitting pro cut head
most trimmer heads are cross threaded, so its opposite of normal threads. you have to turn it clockwise to loosen it. also try soaking it with penetrating oil
Posted on Nov 29, 2008
kenny8262
  • 12 Answers
SOURCE: HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Posted on Oct 29, 2010
Remove ryobi S430 trimmer head
it has a left hand thread which means that to unscrew it you have to turn it in a clockwise direction like putting a nut on a bolt
Jul 02, 2016 | Ryobi Garden
Tip
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
on Sep 17, 2010 | Computers & Internet
Tip
Import flip video to Final Cut Pro and edit flip video Final Cut Pro Final Cut...
Final Cut Pro is a professional video editing application for Mac users and it is widely used even by many Hollywood people on professional movie post-production. If you are a flip video fan and you want to give professional editing to your flip videos, Final Cut Pro is a great choice. However, Final Cut Pro does not allow raw flip videos to be imported to Final Cut Pro and you will need to convert flip video to Final Cut Pro supported formats. Thus, to edit flip video in Final Cut Pro, you can follow the three parts below:
Part One: Convert flip to Final Cut Pro video
Download Doremisoft Mac Flip Converter and refer to the following steps to import flip video to Final Cut Pro.
Step 1: Add flip videos
Click the "Add File" button to add the flip videos you want to edit in Final Cut Pro to Mac Flip Converter.
Step 2: Select a Final Cut Pro supported output format
Click the Profile drop-up list and select
Step3: Convert flip video to Final Cut Pro
Click the "Start" button on the lower right of the interface to start converting flip video to Final Cut Pro.
Part Two: Import converted videos to Final Cut Pro
Step 1: Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Thenselect one converted file from the Choose a File window and press the "Choose" button to choose this file.
Step 2: Find the file in the resources list for the project.
Step 3: Drag the file into the Timeline and then save the project.
Part Three: Edit flip video in Final Cut Pro
Final Cut Pro is a very professional tool with many functions. The following steps will show you how to use the Timeline:
Step1: Edit video and audio timing
Step2: Add transitions
For flip videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Step3: Export video
As mentioned above, Final Cut Pro is a very good tool for professionals. If you want to know better about using Final Cut Pro, you can go to certain Final Cut Pro forums. The most popular one is Los Angeles Final Cut Pro User Groupn and you can find a lot of useful info there.
You might also want to buy a book and study how to use Final Cut Pro, such as Apple Pro Training Series: Final Cut Pro 7 and learn how to professional edit your videos with Final Cut Pro.
If you just want to do some basic editing such as cropping, length trimming and video effect adjustments, you can just use Doremisoft Mac Flip Converter to get the job done by following How to edit flip video with Doremisoft Ma Flip Converter.
on Aug 13, 2010 | Computers & Internet
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
RYOBI 767r.. HOW DO I REMOVE PART #15 (OUTER SPOOL & EYELET ASSE
push down and turn, I think it is reverse threads
May 15, 2009 | Hand Tools
Tip
Import MOD to FCP ? How to import MOD to Final Cut Pro to edit your MOD files
Final Cut Pro is a very sophisticated video editing program made by Apple and provides professional editing of any QuickTime compatible video format including DV, HDV, P2 MXF (DVCProHD), XDCAM, QuickTime MOV, QuickTime MP4 etc. It has become the choice for multimedia journalists using Apple computers and many Hollywood film makers.
However, Final Cut Pro does not support MOD files, which poses a problem if you are using JVC, Panasonic or Canon camcorders that take MOD videos. So if you want to edit MOD in Final Cut Pro, you will need to convert MOD to Final Cut Pro supported formats.
Doremisoft Mac MOD converter provides the perfect solution to letting you import MOD to FCP by converting MOD to Final Cut Pro supported formats.
The four steps below will guide you to import MOD to Final Cut Pro:
Step 1: Add MOD files
Click the "Add File" button to add the MOD files you want to import to Final Cut Pro from your Mac hard disc. Then double click a file or select a file and click on "Open" to add it.
Step 2: Select the output format
Click the small arrow at the end of the Profile field, and you will see the Profile drop-up list. Move your mouse cursor to "HD Video" and click on the "HD MOV" profile. This option will let you convert MOD to FCP MOV. Then you can tick the "Apply to all" option that will convert all added MOD files into selected Final Cut Pro supported format. You can also convert MOD to FCP MP4 if it is what you prefer.
Step 3: Start to convert MOD to Final Cut Pro
Find the round Start button on the lower right part of the main interface to start the conversion. On the conversion window you can see the elapsed time and the remaining time. Now you can decide how to kill the time before the conversion is finished. Then just don’t forget to come back for the converted files you want to import to FCP.
Tip: You can also use Doremisoft Mac MOD Converter to do easy editing such as cropping, trimming, and video effects to your MOD files, click here to see how.
Step 4: Import converted MOV to Final Cut Pro
Launch Final Cut Pro and you can see the layout of the Final Cut Pro Interface. From under the File command at the top of the interface, select "Import" and "Files". Then select one converted file from the Choose a File window and press the "Choose" button to choose this file. Then find the file in the resources list for the project and drag the file into the Timeline and then save the project.
Now you have successfully imported MOD to Final Cut Pro and just start editing!
on Jul 21, 2010 | Cell Phones
Fitting pro cut head
Sep 08, 2008 | Homelite Mighty Lite Lawn Trimmer
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
751 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
