Maytag model LAT9604AAE; in regurlar cycle stopped
Maytag model LAT9604AAE; in regurlar cycle, machine made shrill noise and stopped spinning; belts are "burning / slipping" on the transmission pulley; with electric off, can rotate transmission pulley clockwise; your thoughts; thanks
  • 30 Answers
Check to see if a nail or something is stuck in one of the holes on the inner tub. If not,
sounds like your transmission has locked up on you. Can you turn it the other way? If can not, replace transmission.(or buy new machine)
Posted on Sep 03, 2009
  • 220 Answers
You should be able to rotate the trans pulley in either direction one way is agitate the other is spin,if the trans turns ok try turning the pump.
 If the trans will not turn in one direction,check the holes in the inner tub to make sure there is nothing dropped through any of the holes(nails,screws,bobby pins)
 If the pump won't turn look for similar things stuck inside it,bail or pump the water out before removing hoses..
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
Whirring noise on spin cycle
i have had this problem before you need to repace the tub bearing assembly which reqires special tools to do the job and the whole unit needs to be torn apart
Oct 19, 2007 | Maytag Performa PAV2200
Maytag performa pav3200 washing mach. very load shrill noise during spin
if you just bought it it probably is the shiping pin. it is a large boldt in the back of the front load machines, smaller pin in the side or rear on toploaders. it keeps the drum from spinning in transit. people forget to pull them all the time. especially if you installed it yourself. If that isnt the problem, try leveling it. Newer machines spin much faster than older ones and one tiny bit off level will make it rattle and shake.
Jan 06, 2013 | Maytag Performa PAV3200
Washing machine will not agitate or spin. We can hear the motor running with a shrill noise.
Under the door there is a switch -if broken it will not let the spin cycle spin - its a safety thing.
like when you open the washer door when the spin cycle is on and it stops spinning until you shut the door again, when you shut the door the switch activates.
cost around $3.00 - put in with a screw driver
good luck -- aloha
Feb 13, 2011 | Roper Washing Machines
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
331 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
