Question about Acer Computers & Internet
I replaced pwr connector with a great deal of trouble, lost resistor R298 and R299 I would like to know what sizes they are. Thank you in advance if you could help.
    Sergeant:
  • 175 Answers
You didn't mentioned the exact model of the motherboard. Well it's better to find actual value of the resistance through this calculator.
http://www.electronics-lab.com/articles/basics/resist/index.html
Regards;
Hassan
Posted on Sep 03, 2009
My hp 7060n won't pwr on. I checked the ps it test
I don't think you know what you are doing. No computer will boot without memory! And no mo bo will work without the 4 pin connector being attached to mo bo along with the 20/24 pin mo bo connector..
Listen, keep it simple and just plug in another known working ps to see if unit works. If it still does not work, then your issue could be corrupt bios, bad hard drive, corrupt OS, bogus peripheral, bad memory.
Sep 16, 2017 | Computers & Internet
Having trouble removing the harness of the old resistor from the back of the blower motor. any advice
the connector is probably melted to resistor? replace the resistor and the harness connector. this is also called a pig tail replacement connector.
Apr 21, 2011 | 2005 Chevrolet Silverado
Blower motor on 2000 toyota camry works only on hi settig
Hi!!
The blower motor speeds are ultimately controlled by the Blower Motor Resistor, when the Resistor becomes defective, current goes right thru it and the Blower Motor only operates at max. speed. Replacing the Resistor is a simple task. Locate electrical connector to blower motor, trace back wiring no more than 8" to next plug, The device where the plug is connected to is the Blower Motor Resistor, disconnect plug and remove the two screws, remove and replace Resistor.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 15, 2011 | 1998 Toyota Camry
I have a Acer Aspire T671 PC Windows Vista I hav lost sound from the PC, my sister was on it and started clicking all amnner of things and suddenly then sound was lost. I have tried going through different...
no sound
software problem -go2 device manager &under device if u see yelow ? mark so tht driver is missing from my computer REINSTALL IT
Else hardware problem thn Replace speaker
Feb 21, 2011 | Acer Computers & Internet
Heat fan stopped working..is it a fuse?
Hi!!
It could be the Blower Motor Fuse or Relay and they should be located in the cabin Fuse Box, if both are OK, it could be the blower motor resistor, located on the blower motor housing, it is the part where the electrical connector goes into and it's got a pigtail connector that goes to the blower motor, it is attached to the blower housing by three screws. Here are some pictures for better identification.
To test it, make sure the electrical connector has voltage when the FAN is on, if voltage is present, it means relay and fuse are OK, plug the connector into the resistor and check voltage on the pigtail connector, if voltage is present, the resistor is OK, voltage varies according to the speed selected. To check the blower motor, apply 12 volts and ground the the motor terminals, it should kick in in Hi speed, if not Replace Blower Motor.
Nov 09, 2010 | 2000 Pontiac Grand Prix
The air conditioning works, but only when the switch is turned to high. We tried replacing the switch, which did not work.
Good that you replaced the switch, but usually the resistor is also bad when this happens. The resistor is usually somewhere under the dash screwed into the duct with 2 screws and has a connector coming out of it with several wires. Remove the connector and unscrew the resistor. It will probably look burned up. If so, replace it.
If not, the wires have probably burned up somewhere along the way. If you have trouble finding the resistor, please let me know and i will try to locate it for you. It looks like this:3067b47.jpg
Sep 26, 2010 | 1995 Nissan Altima
Own a Nortic Track apex 4100i. Great treadmill.
You need to have the power supply board rebuilt with larger Caps and resistors. Look on the internet under treadmill repairs. The board is easy to replace yourself so don't have someone come in and overcharge you. I think about 4 screws and two plugs.
Feb 10, 2010 | NordicTrack E4000 Treadmill
No audio
I know that a couple of you have had the same problem with the blowing 0.47 ohm resistors. I had responded quite a wile back, but forgot to make any updates. Kostiko is correct about the problem relating to these two 0.47 ohm resistors being blown. In my case on two different Haman Kardon models, this was true, but there could also be another issue. What i have found is even after replacing these resistors, the problem appeared to still be there. What was happening was that right after turning the receiver on, the resistors would blow again. What you need to do is replace the two small ceramic disc style capacitors on the same pcb as the fusible resistors, as they could be shorted as in my case. You could remove these capacitors completely, or replace them with a similar size of the same type, as they are really just there for filtering higher frequency noises from the power supply. You can check them with your multimeter first. They shouldn't shorted even in situe. I forget the size, but they are approximately 100 nano farads. Good luck. I have done this to my AVR135, and it has been running great for about 6 months now.
Jul 07, 2008 | Harman Kardon AVR 335 Receiver
Computers & Internet Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
