My Nad CI9060 went into protection mode after a lightning storm and will not reset anymore. Can I, as the enduser fix this problem or does the amo have to be send to NAD service? Any advice would be appreciated. Thank you
  • 1,165 Answers
Sounds as if amp got some of that lightening.id send it in..
Posted on Sep 06, 2009
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
My Emerson lf46iem4 46 inch tv stopped working after a storm... What part would I replace to fix it?
IT COULD BE THE POWER SUPPLY GOT SHOT OR THE TUNER DEPENDING ON THE CONNECTION WHEN IT WAS IN USE .SOME TIMES THE TUNER GOT SHOT WHEN THE SET IS CONNECT WITH THE COAX CABLE LIGHTNING WILL SURGE THROUGH THE CABLE IF IT IS NOT GROUNDED PROPERLY ...GOOD LUCK
Oct 12, 2014 | Emerson Televison & Video
How can I get Dynex TV out of "protection mode"?
the protected mode kicks in when there is a safety issue with the receiver. This usually comes from an overload to the system via a short in the system or perhaps a surge in power. Your receiver shuts down, and you'll need to shut the entire system down to fix it.
In some older homes, some of the wiring doesn't deliver the "cleanest" power, delivering minor power surges to the items you plug directly into the wall. If your receiver is plugged directly into the wall, purchase a surge protector to stop this
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYa9W0Mi
God bless you
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYZm8THG
Jul 20, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
How do i stop lightning from getting in my hdmi lines and shocking my tv? 5 tvs went down in one storm
I would recommend getting a surge protector and using that to protect your televisions. This usually will stop something the lightning from killing your tv's.. I have a surge protector and can still use my tv, computer, anything I have plugged in during a storm.
Oct 22, 2012 | Vizio 42 in. LCD TV
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Model TDC2075A Sansui Had lightning storm, lost power no close lightning strike. TV will not power up, don't know if it has internal protection or is power supply went out
you mite try replacing the ac fuse 1 time-if it blows again there is a short in the power supply-i would then check rectifiers in the primary of the power supply-then check the fet-if any of them are shorted replace them
Sep 04, 2009 | Sansui CDVD1900 19" TV/DVD Combo
I have an av316 NAD, surround sound Amp. Just got back from repair. The wires to the speaker may have been reversed when hooking, the amp went into protection mode, can I fix this problem. It wont come out...
Having the speaker wires hooked up backwords will not cause protect mode. If the wires were crossed (in other words shorted), that would. Disconnect all speaker wires, if the unit is still in protect mode, than the output transistors are probably shorted and the unit will again require service. Upon return from service, I would turn on the unit without speakers to insure that the unit at least works that far. Also, if you have an ohmmeter, measure across the speaker terminals. You should read either 3 or 6 ohms. If you read 0, the problem is a shorted speaker that then shorted the amp.
Keep us posted.
Dan
Jan 20, 2009 | Audio Players & Recorders
Ethernet router not working
more like lightning toast..time for a new one..and protect it with some power protection this time.
Aug 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
NAD 304 power indicator
Change resistors 333 & 334 - 47k-1W
Jan 05, 2008 | Audio Players & Recorders
140 people viewed this question
 Grubhead
Grubhead
