Question about RAD Data Communications RAD RIC E3/ETH (RIC-E3/ETH) Bridge
Phone won't ring
My krazr phone won't ring. it is not on vibrate and sound works when testing ringtones, however when calls come in....nothing. Do you have any solutions?
0 characters
1 Points
I have a D-Link G604T Modem/Router and ADSL light blinks after I have a phone call and wont log on to Internet.
sounds like you may not have filters correctly installed. You should have signal filters which will seperate the Internet signal from the standard phone signal. There should be one which looks like a cable splitter with a symbol for phone and modem... make sure these are connected the correct way. If you also have any other phones or fax machines connected, they should have a filter at the socket....
Feb 11, 2013 | D-Link DI-604 4-Port Cable/DSL Router...
Siemens 4200 modem won't connect to internet
First unplug the power cable from your modem. Then press and hold the power button of your modem for at least 1 minute. Then plug in the the power cable and wait until all the lights become stable. Then you can try to go online to check.
If after this step you will not be able to go online then contact with your ISP provider.
For More information you can call at +1-877-255-3353 or visit our website
Mar 05, 2012 | Siemens SpeedStream 4200 (13A4200001)...
What to do if dsl light is blinking
This likely means that your DSL modem is not trained up with the DSLAM. - Geek talk for your modem is not connected to the phone company's equipment properly.
1.) Remove power from the modem
2.) Remove all devices (including the DSL modem) from all phone jacks in the house.
3.) Add the DSL line back to the wall jack, taking care to plug the wall jack into the correct jack on the DSL line. (Do not use a DSL filter on your modem!)
4.) Power up the modem/
Still not working? Continue...
5.) Try a different phone jack
6.) Try a new phone cable between the wall jack and modem
7.) Call the phone company for further assistance.
Dec 18, 2010 | Siemens SpeedStream 4200 (13A4200001)...
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when...
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
Dec 25, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Intermittent ADSL connection
The DSL light blinking or going out indicates that the DSL modem is loosing sync. This is usually caused by noise on the line. When you get the DSL service you should be given filters to put on all of your phones so that the phones will not interfere with the DSL signal. Those filters need to be attached to anything connected to the phone line that has the DSL on it except for the DSL modem. Other than that the problem could be on the service providers end, something outside your home, or the DSL modem going out. I would suggest that you verify everything is filtered, then contact your service provider so they can run test on your DSL line.
Dec 23, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Laptop can't connect to internet
1) Your Network or DSL router may have bad or missing information. Powercycle your router and/or rebuild the configuration in your router.
2) Double-check your cabling to the computer. Make sure you have the correct type of cabling, straight-through CAT 5 or possibly a crossover cable and try another cable or test the cable to make sure its working properly.
3) Check your network card to make sure its configured correctly and working properly. Many times setting the network card to 10Mbps/Full Duplex will solve this issue. To do this, open Control Panel, System, Device Manager. Go to the properties of the Network card, click on the Advanced tab and find the Link Speed and Duplex section. Change it from Auto Detect to 10Mbps/Full Duplex.
4) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
5) Check your IP address assignments and workgroup settings in the computer for accuracy. Statically assign IPs to the computers in your network.
6) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Nov 19, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Cant connect to "SOUL" adsl
First, just so you know, some devices (modems) just will not work on a provider's (ISP) network.. did you call your Internet Provider and ask it this device is compatible?
When you updated the firmware, did you receive any messages about failures? any messages at all?
Dec 22, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Is it possible..
Two things:
1) Is your phone bill paid?
2) Have you installed filters on the phone line and data line?
3) as you said, check for anything sticky on the speedstream itself, something might have been spilled, or even water for that matter.
Oct 02, 2007 | Siemens SpeedStream 4200 (13A4200001)...
RAD Data Communications RAD RIC E3/ETH (RIC-E3/ETH) Bridge Logo
102 people viewed this question
Top RAD Data Communications Network Bridges Experts
john smith
Are you a RAD Data Communications Network Bridge Expert? Answer questions, earn points and help others
