Question about Whirlpool Calypso GVW9959K Top Load Washer
SLOW COLD WATER FILL - Whirlpool Calypso GVW9959K Top Load Washer
  • 867 Answers
First thing to do is remove hose, check for stone build up on screen filters. while the hose is off check how your water supply runs
Posted on Sep 03, 2009
SOURCE: Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Posted on Aug 26, 2007
barkencoa
  • 3463 Answers
SOURCE: sporatically slow cold water fill (Kenmore Series 80)
Could be you have trapped the hose at the rear of the m/c.
If this is not the case, then I suspect you will need a new cold inlet valve fitting..
Please leave feedback.
Ta.
Posted on Dec 09, 2008
SOURCE: slow cold water fill kenmore top fill mashine
hi I had the Kenmore washing machine , and now have whirlpool, and have changed the valve on both.
you will need a screw gun or phillips scew driver a ratchet set with 1/4 and 5/16 sockets and a pair of channel locks.
turn off the water valves and unplugg the machine.
disconnect hoses from the wall and drain excess inton washer.
pull machine out and make sure you have enough room to work.
check to see if there are two screws under the control panel. if there are unscrew them anmove the control panel tosee if you have access to two clips that hold the control panel to the back of the machine.
if you remove the clips remember how they came out. then remove the screws and bolts from the back panel.
it is reccomended to change the hoses every year but no onew does that.but since you are working with the valve is would be a good idea.
once you get the rear panel off, the valve should be easy
good luck BRouth3bme
Posted on Jan 04, 2009
SOURCE: Slow cold water fill in washing machine
Take out the screen on the cold water side of the fill valve where the hoses attach, its probably clogged.
Posted on Mar 17, 2009
  • 770 Answers
SOURCE: very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Posted on Jun 19, 2009
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
COLD WATER RUNS VERY VERY SLOW
heatman101
Aug 09, 2011 | Kenmore Washing Machines
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Mar 31, 2011 | Washing Machines
Cold water runs really slow when filling up washer,starts out normal but then goes to just a trickle until filled.
heatman101
Mar 30, 2011 | Washing Machines
COLD WATER WILL NOT FILL; NO COLD WATER RINSE. MODEL NUMBER 110 26452502
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 08, 2010 | Kenmore Washing Machines
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Mar 17, 2009 | GE Washing Machines
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
