Question about Everex StepNote VA4103M Notebook
Upgrade cpu My laptop is an Everex Stepnote nm3500w.I want to upgrade the cpu to a dual core x 2. I am wondering if the laptop cpu is soldered in or can I just remove and replace. And if I would need to do anything else like BIOS ETC.
    New Friend:
Yes, you can replace the processor in the LM7W. You can use either "Banias" or "Dothan" based Pentium M or Celeron M processors with a Socket 479 interface and 400MHz bus.
However, the laptop's BIOS will probably not recognize these other processors, so they will boot up in their slowest speed. You will need a third party processor manager like RMClock Utility to unlock the higher speed and lower voltage settings.
Also, if there are any processor microcode updates from Intel, you'll miss out on them. There is a rare chance this might cause issues. YMMV.
I've tested Pentium M 745 (SL8U6) and 1600 (SL6FA) processors and they both seemed to work.
Posted on Oct 26, 2015
  • 40 Answers
You can at most upgrade memory, rarely video, but I never seen ugrading a CPU on a laptop, most of the time the CPU is soldered and the MB does not support upgrade.
Posted on Sep 03, 2009
  • compwhiz78 Feb 27, 2011
    Not true, only most Netbooks are Soldered to the mainboard, almost all CPU's are removeable from MB's Except the Via CPU Chips.
I seem to not be able to find any wifi drivers for my Everex StepNote NM3500W laptop im on xp an need to access my internet on my other pc.
Try this drivers for your wifi adapter.
ATHEROS AR5005G Wireless Network Adapter for XP -> Download
Hope it helps.
Nov 11, 2010 | Computers & Internet
Oper. sytem will not load w/ 2 Gb upgrade only w/ 1Gb and original 512 in an everex nc1502 stepnote
Is your "2GB upgrade" one memory-stick, or two?
If it is one, then it's possible that the motherboard does not support so much RAM on one stick.
If it is two, then remove one stick, and try.
If it still fails, then remove that stick, and try the other stick.
If it still fails, then try your original 512KB stick.
If it still fails, then try your original 1GB stick.
Nov 20, 2009 | Everex StepNote NC1502 Notebook
Which processor can I upgrade to?
Honestly, it is normally not worth it to upgrade the cpu on a laptop. Laptops are build to deal with a certain amount of heat and adding a faster cpu can cause the current cpu cooling fans to not get the job done anymore. You will seem instability in your system and could possibly damage it due to over heating.
With that said you would only be able to upgrade to a very slightly higher speed cpu and your money would be better spent else where. Some good ways to speed up a laptop are max out your memory or install a faster hard drive. For example if your current drive is a stock 5400rpm unit a 7200rpm drive would give you a nice boost. You could also look into a solid state option.
Both these upgrades will give your laptop a better boost without the hassle and risk of a cpu upgrade.
Aug 24, 2009 | Toshiba Satellite A105-S4334 Notebook
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
Everex stepnote VA2001T won't boot
i have the same problem / maybee its a lcd malfunction
Dec 28, 2008 | Everex StepNote VA2000T Notebook PC -...
Need audio device or sound card
when you have the audio device and sound card,search drivers
Sep 19, 2008 | Everex StepNote VA4103M Notebook
Processor
I told you my opinion, If I was in your shoes I won't upgrade the CPU.Professionals do not do works against Factory specifications, and I fixcomputers for living.
Acer says Pentium dual is not supported on Acer 4315, I can only tell you not to do such an upgrade.
Itwould be the same as if you ask me if you can mount a Jaguar engine ona Mini, yes, for sure there is the way to mount it, but the car won'twork as it is supposed to, and risk to blow at first corner.
If you really want to replace your CPU consider the following.
Acersays pentium 2 dual core is not supported on 4315, if you do ityourself you risk to damage the computer. Do not do the CPU upgrade ifthis is your only laptop, or if you care of this laptop, chance ofdamaging laptop are high. This kind of upgrades are done more as anexperiment.
I know Core 2 Duo T5300 1.73 Ghz had been installedsuccessfully on Aspire 4315, Acer says not to install any core duo, Iknow for sure Pentium duo T5200 1.6 Ghz works on Aspire 4315 with noneed for replacing cooling system.
Both chipset are difficult to find, best place to find them is Ebay.
Check this link for an extensive report on this matter:
check also: Is it worth upgrading the CPU on Acer Laptops?
Aug 10, 2008 | Acer Aspire 5100 Notebook
Cpu upgrade for hp 530 laptop
the chip is soldered to the motherboard an i would not mess with that u will end up with a paper weight
Jun 25, 2008 | HP 530 Notebook PC
Everex StepNote VA4103M Notebook Logo
598 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
