Question about Nokia N95 Cellular Phone
How to set uo yahoo mail account in nokia n 79?
Why do I keep being asked to re-enter a password for Yahoo! on my 5c?
To set up a Yahoo! Mail account for sending and receiving emails in iPhone Mail:
  • Tap Settings on the iPhone Home screen.
  • Go to Mail, Contacts, Calendars.
  • Tap Add Account... under Accounts.
  • Choose Yahoo!.
  • Tap your name under Name.
  • Type your full Yahoo! Mail address under Address.
  • Enter your Yahoo! Mail password under Password.
  • Tap Next.
  • Make sure Mail is ON.
  • Tap Save.
  • Press the Home button.
Nov 08, 2014 | Apple iPhone 5
I cannot set-up my yahoo mail on N900
Pop Email account setup steps for Nokia N900
  1. Click on the "New Account" and start the 'Account Setup Wizard' by tapping 'Next'.
  2. Select your country/region and service provider or just select 'others' and name the Account.
  3. On the 'Account setup: User details' screen, provide Name, Username, Password and Email address and tap 'Next'.
  4. On the 'Account setup: Incoming Details' screen, select Account type to 'pop3?, provide pop incoming server details, keep the 'secure authentication' option unchecked, and also keep 'Secure connection' to none(of course if you don't want to use secure connection) and tap 'Next'.
  5. On the 'Account setup: Outgoing details', provide outgoing smtp server address, select the 'Secure authentication' to 'Login' option, 'Secure connection' to none and tap 'Next'.
  6. Now you are on 'Account setup: Complete screen', tap the 'Advanced Settings' option and change the default port 25 to whatever port your server requires. Most email servers these days do not use default 25 port, rather 26 but you need to confirm this at your hosting server panel.
  7. Now tap 'Finish' and you are done.
Just send a test email to yourself and if you have setup everything correctly, message will successfully be sent and received.
Hope that helps!
THANKS FOR USING FIXYA
Feb 28, 2011 | Nokia N900 Smartphone
Trying To set up yahoo mail in my HTC phone need details
You will need adjust the mail application's POP settings to get your Yahoo! Mail messages into it.
POP access is a service for owners of one of the following:
Yahoo! Mail Pop Access & Forwarding
Yahoo! Mail
Plus Premium Services
A Broadband account
A Small Business account
Please note that access to IMAP servers is not available.
To use an email client or application to send and receive Yahoo! Mail messages, you may need to designate a new incoming (POP) mail server and a new outgoing (SMTP) mail server. Consult your owner's manual for instructions on designating servers in the email application.
If you can't add new POP or
SMTP servers, you will need to change your current server settings.
Before you make any changes, write down your current settings. You might need to revert to your original settings later if you decide to send and receive messages from your other email addresses.
The following steps will help you find the POP settings for your Yahoo! Mail account and configure it:
Log onto your Yahoo! Mail account from a PC.
Click Options > Mail Options.
Click POP & Forwarding.
Click Set up or edit POP & Forwarding.
Click POP Settings.
Note your Server Setting information. Your phone email client or application will ask for these settings:
Incoming Mail Server (POP3)- for example, pop.mail.yahoo.com.
Outgoing Mail Server (SMTP)- for example, smtp.mail.yahoo.com.
Account Name/Username, your Yahoo! Member ID- for example, myuserID.
Email address, your Yahoo! Mail address- for example, myuserID@yahoo.com.
Password, your Yahoo! Mail password- for example, l0ngitudin*l
Notes:
POP server settings may change from time to time and you should confirm the current POP server settings in Yahoo! Mail if it is not working.
When using
Microsoft Outlook, replace the "@" in your address with "%".
As an alternative to configuring Yahoo! Mail POP mail configurations, go to:
http://mobile.yahoo.com/mail
http://help.yahoo.com/l/us/yahoo/mobile/...
Enter your phone number and send a link to your phone; the best Yahoo! Mail experience will be suggested to you.
Have a nice day
Jan 01, 2011 | Yahoo Mail
What are the POP and SMTP settings I need to use for my Outlook account if I am using Yahoo. My ISP, AT&T, said I needed to contact Yahoo for these settings.
Yahoo POP3 and SMTP Settings:
Find below the basic POP3 settings that you need to configure in the email program where you want to access Yahoo mails.
Incoming Mail (POP3) Server: pop3.mail.yahoo.com (Use SSL, port: 995)
Outgoing Mail (SMTP) Server: smtp.mail.yahoo.com (Use SSL, port: 465, use authentication)
Account Name/Login Name: Your Yahoo! Mail ID (your email address without the "@yahoo.com")
Email Address: Your Yahoo! Mail address (e.g., user@yahoo.com)
Password: Your Yahoo! Mail password
Note that you also need to enable "Web & POP Access" on your Yahoo Mail account to send and receive Yahoo! Mail messages through any other email program.
Nov 15, 2010 | Yahoo Mail
I have a nokia 5800 on 02...i use yahoo for my email...on the connection settings for email it hasusernamepasswordincoming mail serveraccess pointmailbox typeport etc etc..ive deleted the 4digit password...
There are no passwords for yahoo server in configuration (i.e.) predefined in settings.
It must be the password for your E-mail account, Try adding it you should succeed
May 24, 2010 | Yahoo Mail
I want to set-up Yahoo mail on my mobile N97
If you have yahoo premium account, you can email them and ask for POP3 or IMAP settings. If you have yahoo free account, on your N97 browser open up http://m.yahoo.com/ and click "Mail" on the right side to login to your email.
May 02, 2010 | Nokia N97 Cell Phone
How do i link my free yahoo email account to MS Outlook 7?
To setup your Yahoo in MS Outlook 2007, please follow the procedures written below:
1. First of all, you must enable POP3 in your yahoo mail account. If your current yahoo setting for the preferred content is “Yahoo US”, it requires “yahoo mail plus”. But if you change the setting as “Yahoo Asia”, then you can enable POP3 access in your yahoo mail account. To do that:
- Sign in to your yahoo mail account. (I assumed that you switched the yahoo mail options to “All-New mail” view from “Mail Classic” view.)
- Click on your “Display Name” and select “Account Info”
- Continue signing in yahoo account info verifying your password.
- In your yahoo account info page find the “Account Settings” section.
In the “Account Settings” section, check the current settings for “Set Language, site, time zone” content. If it is “Yahoo! U.S.”, then click “Set Language, site, time zone” link.
- In the “Edit Member Information” page, click on the New Setting option and change your current preferred content settings to Yahoo! Asia and click “Finished” button.
- Click “I Accept” button on the “Terms of Service” screen to proceed further.
- The preferred content will be “Yahoo! Asia”. Click the “Finished” button to save the settings.
- In your yahoo mail box page, click on Options and select More Options…
(NOTE: CONTINUED ON THE NEXT MESSAGE)
Apr 08, 2010 | Yahoo Mail
I am using Nokia N97, and want to configure Yahoo Mail, however I am unable to get the yahoo mails on my phone. can you plz suggest me the correct incoming and outgoing settings for my yahoo account for...
Incoming e-mail:
  • username: your email address
  • password: your password
  • Incoming mail server: pop.mail.yahoo.fr
  • access point used: sl2sfr
  • Account type: POP3
  • Security: SSL / TLS
  • Port: 995
  • APOP secure login: Enabled
Outgoing e-mail:
  • username: my email address
  • password: my password
  • Outgoing mail server: smtp.mail.yahoo.fr
  • Port: 465
Mar 06, 2010 | Nokia N97 Cell Phone
Sir, pls how will i get the yahoo mail password for my Nokia 6500. the settings of yahoo mail and my mail address is on my phone but any time i want to check in my mail,it calls for yahoo mail password
If you have a Yahoo mail account then you must be having its password too. Same password will work everywhere you use Yahoo mail. it does not matter if it the PC or the laptop or the mobile phone or a PDA.
But if you have forgotten the password then you will have to go to the Yahoo login page and click on "Forgot your password" and take action as directed. You will get a new password in your email.
Dec 12, 2009 | Nokia 6500 Classic Cellular Phone
What incoming and outgoing mail server info. do I need to set up
Hi, For yahoo mail you need upgrade to yahoo mail plus (@ $19.99 per year) to get the full pop3 service for access to Outlook,Incredimail, Thunderbird and others.
For more info on setting up your pop3 account see the links below.
http://help.yahoo.com/l/us/yahoo/mail/cl...
* Incoming Mail Server (POP3): plus.pop.mail.yahoo.com
Use SSL, port: 995
* Outgoing Mail Server (SMTP): plus.smtp.mail.yahoo.com
Use SSL, port: 465, use authentication.
If you have “yahoo.co.uk” address some users can get free pop forwarding see below.
Click “options” (top right) on your mail page>mail options>pop and forwarding>
Set up or edit pop & forwarding>type in the address you want to forward to and
click save.
* Incoming mail server (POP3): pop.mail.yahoo.co.uk
Use SSL, port: 995
* Outgoing mail server (SMTP): smpt.mail.yahoo.co.uk
Use SSL, port: 465.
Note: In order to be able to send emails from outlook and others through/to yahoo (pop3) you need to pay for a yahoo mail plus account.
http://help.yahoo.com/l/uk/yahoo/mail/cl...
Apr 10, 2009 | Yahoo Mail
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
