Question about Dell Dimension 4700 PC Desktop
I have a Dell Dimension 4700 that doesn't recognizable the disc drive. When I search in "removable storage" nothing shows up. How can this be fixed?
  • Herbert Fields May 11, 2010
    Does the drive powerup? can you insert a disk? If you have opened the case to add hardware the cables might be loose or the drive could be bad.
    Problem Solver:
  • 10 Answers
Well 'removeable storage' is not the corret place to look for a disk drive that refers to usb connections or memory cards. If the disk drive is not showing up in 'my computer' then you need to look in device manager to see if it's showing up there. I'm goin to assume you are running xp. RIGHT clik on 'my computer' then clik 'properties/hardware/device manager.' Then look at the list of things there you're looking for a listing for dvd/cdrom drives. It should be there. If there is a ?? or a !! beside the listed drive then the drive has an error in the driver. You'll need to then RIGHT clik on the listed drive and 'uninstall' dont worry if it throws up a warning at you. Just do it. Then restart the pc it will automatically try to reinstall the drive. Check 'my comptuer' and see if you now have a drive listed. If not then go to the following webpage and do the process shown: http://support.microsoft.com/kb/314060
Posted on Sep 03, 2009
    Problem Solver:
  • 11 Answers
Install the drivers before you install the disk drive.
Can't open my dell dimension 4700 to replace cd-rw drive
Below is a link to the service manual. There is a secion there on replacing the CD/DVD drive. It will also direct you on how to remove the side and front cover to get the drive out.
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Mar 27, 2012 | Dell Dimension 4700 PC Desktop
Replaced 80gb with 500gb sata wd green also have 500gb sata as second drive bios level 10 sees both in setup but nothing is available in boot including well used cd drive- system dell dimension 4700- any...
Did you remember to set one drive as a master and the other as a slave driver?
To do so. Removed the drive and look on either the front or back and it'll give you the jumper set up.
Master is the primary boot drive and the slave will the be media, documents drive
Aug 22, 2011 | Dell Dimension 4700 PC Desktop
4700 goes through initial Dell screen then blue screen with blinking cursor and nothing more. Have tried F8 - no go - original message suggested I had installed new hardware or software but I haven't...
This could be caused by several faults. See the link below, the scroll down the "Advanced Troubleshooting" section, then click on the "Power lights" or Diagnostic Lights" to help you start looking for the problem. You may want to download and print out some of this information using another PC.
http://search.aol.com/aol/search?enabled_terms=&s_it=comsearch50&q=Dell+Dimension+4700+Specs
You may have an operating system problem as well. You can change the boot sequence of your PC by pressing F2 early in the bootup and using the original or restore CD/DVD, you can find out out if the hard drive has issues or if you need to reinstall Windows. Hopefully, you have a backup of your files. Reinstalling Windows can result in data loss.
Aug 16, 2011 | Dell Dimension 4700 PC Desktop
I installed the HD to double the storage capacity of my Dell Dimension 4700 computer. My computer does'nt recognize the new addition or format the new HD. I connected the new HD data cable but did not...
No power cable = no power to the board of the HD = no way to communicate with the motherboard = the motherboard doesn't know the hd is in there.
Plug the power cable.
Jul 16, 2011 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Loging screen doesnt show up
There is problem with Start Up That mean sysprep... which means system preparation... Go to advance option and select safe mode with command propmt and type it there chkdsk /f .. press y and restart computer .... it will chk the system file in disk and fix it.
Oct 14, 2009 | Dell Dimension 4700 PC Desktop
Beeps, wont boot up
Most of the time when it beeps, and there is nothing show on the computer screen, it is a RAM problem. A stick of ram may have gone bad. If you have two sticks of ram in the computer, you can try to remove one stick at a time to see which one might have gone bad.
Mar 23, 2009 | Dell Dimension 4700 PC Desktop
Is this hard drive sata or ide
It is SATA - Serial ATA (DELL Dimension 4700)
Jan 17, 2009 | Dell Dimension 4700 PC Desktop
Move HD from Dimension 4300 into Dimension 4700 / XP HomeED both.
You can change the hard drive, but it will create major driver issues.
You will have to let the computer tell you which drivers are missing and go back and download them from the manufacturers website or use the software that you have.
You cannot damage the hdd doing this.
The easy way to do this would be to install this as a secondary hdd, this would allow for more storage and less problems.
Dec 30, 2008 | Dell OptiPlex GX270 PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 PC Desktop Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
