Question about Canon PIXMA MX310 All-In-One Printer
ON THE SCREEN SAY STACK THE PAPER
I HAVE A PROBLEM WITH A COPY MACHINE, I TRY TO MAKE A COPY AND ONE A THOSE LIGHTS GONES ON (ALARM)
Alarm light
Paper Jam:
Clear the paper jam.
If the printer does not automatically resume printing, press the control panel button.
No Paper/ Misfeed:
  • The paper cassette may be out of paper or not properly installed.
    If it is empty, load a new stack of paper into the paper cassette.
    If there is paper in the paper cassette, make sure it is straight.
    If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
  • Reduce the amount of paper in the paper cassette, and then try again.
  • Make sure you use paper that meets Brother's recommended paper specifications.
  • Re-install the paper properly, and then press the control panel button. The printer will start printing again.
May 06, 2013 | Canon PIXMA MP495 InkJet Printer
Download Cannon resetter for error code 5B00 model MX416
FIRST STEP : ENTER SERVICE MODE
<Service mode operation procedures>
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the
buttons). The COPY button lights in blue to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each
time the Stop/Reset button is pressed, the Alarm LED and COPY button light alternately, Alarm in orange and COPY in blue, starting
with Alarm LED.)
4) When the COPY button lights in blue, press the Stop/Reset button 4 TIMES
SECOND STEP : DOWNLOAD THE FOLLOWING PROGRAM.
www.4shared.com/get/zc4OMn2_/Service_tool_v3400.html.
1. Run the program
2. Set the region according to your location, then klik set
3. klik set on the Ink Absorber Counter
4. Prepapre 1 sheet of paper.
THIRD STEP : TURN OFF YOUR PRINTER AND THEN TURN ON AGAIN.
FINISH
Sep 06, 2012 | Canon Office Equipment & Supplies
There is a new stack of paper in the tray, but when I try to make a copy I get a p errpr message.
There is a paper jammed in the copier. Remove it and try again. If this doesn't work try feeding paper from the tray on the right side of the machine.
Dec 24, 2010 | Sharp AL-1451 Laser Printer
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
How do you reset an H5-01 error code on Sharp Color MX2300 Copier.
Hello
Most error codes can be cleared by removing the paper jam and then rebooting the machine. When an error code occurs, make a note of the code and then follow the instructions on the control panel for clearing it.
Paper jams can be caused by a variety of issues in the copy machine, but jamming can commonly be caused by improperly loaded paper in the trays or dirty paper feed rollers.
If you get repeated paper jams, remove the paper from the trays and inspect the stack. Look for folded corners, especially on the bottom of the stack. Fan the paper thoroughly and then reload the stack into the tray. Check the paper guides to ensure they are not too tight or too loose. Both conditions can cause paper jams.
If you can see the paper transport rollers by opening the ordinary access covers and panels inside the machine, cleaning them might help reduce paper jams. Shut the machine off and unplug it, then take a soft, lint-free cloth dampened with water and wipe those rollers off. A buildup of toner and paper dust can cause them to slip while transporting the paper.
Oct 21, 2010 | Office Equipment & Supplies
I had the Bro 8840D repaired following a paper jam. I am unable to get it to pull paper through. Says paper jam, but no jam exists. The tech repair shop said a switch had been flipped when the first jam...
okay, try this...clear the paper jam message and try to make a copy using the manual bypass (MP tray) located on front of machine. if copy comes through okay, then chances are you have a problem in main cassette area. pull cassette out, and make sure the rear stop inside cassette is not pushed too tightly against rear of paper stack. should leave about 1/8" gap. if thats okay, then sounds like you may need your paper pickup roller replaced. sounds like your repair shop just fixed the error, not the cause of the error.
hth,
razors
May 24, 2010 | Brother MFC-8840D All-In-One Laser Printer
Alarm and data lights are on. Won't feed paper and makes load noise when you hand feed the paper
When the alarm and data lights are on, means that the toner is empty and you wont be able to print until you purchase a new toner and replace it.
Copy the link below to see how to replace the toner.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000000/000065/faq000065_011.html?reg=us&c=ca&lang=en&prod=hl1440_all&Cat=7
Apr 10, 2010 | Brother HL 1440 Laser Printer
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
Canon PIXMA MX310 All-In-One Printer Logo
18 people viewed this question
old marine
old marine
