XEROX 5328 Has an error E40. How to take care of it. I do not have any manual.
  • 239 Answers
Sometimes this jam can be the exit rolls. If they are the spongy upper rolls they flatten out and no drive. The lower rolls can be smooth and glazed. Try replacing the upper rolls if nothing else fails. If the upper rollers metal holders are bent they may not be down on the drive rollers and not able to grip the paper to drive it out the machine.
On some 5028 5034 family machines, the exit roller is driven by the exit motor.
The exit circuit board can cause the exit roller motor not to work, very intermittant also and hard to detect. This board is located in the duplex paper feed modual, not an easy task to service.
Not seeing the machine it is hard to troubleshoot the machine.
These problems can come from a paper feeder with worn clutches or paper feed registration clutch binding or slipping, even a registration paper feed clutch not operating correctly.
Good luck.
Posted on Oct 20, 2009
    Novelist:
  • 208 Answers
That is an exit Jam code in the fuser.
You may just have one of the fingers bent straight down blocking the paper.
There also may be a secondary code that is causing the E-4-0.
But that is where to start. Look under the exit web cover for a piece of paper crumpled in that area.
Once there you may have to remove the fiser web cover to remove that jam and straighten out the finger.
MAKE SURE IF YOU GO INTO THAT AREA TO UNPLUG THE MACHINE.
Posted on Dec 10, 2007
Error code - E602-0001
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=DC12CP&Xlang=en_US&Xcntry=USA&prodName=DocuColor%2012%20Copier/Printer
Documentation, manual, all error codes are in there download the manual, it will tell you what to do. Look right to bottom carefully, the information you need is there, look carefully.
Mar 31, 2010 | Xerox DocuColor 12 Printer
Electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Apr 09, 2009 | Electrolux Washing Machines
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
RE is the Xerox 5328 discontinued as a model?
Yes. It has been for some time. Xerox will not service it, but there are many reputable dealers that will. Parts are available and so is service. Just not by Xerox direct.
Oct 31, 2008 | Xerox WorkCentre M-24 Color Copier
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Oct 03, 2008 | Office Equipment & Supplies
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
XEROX 5328 COPER
Total weight is about 200 pounds. But, that machine comes apart.
You can take off the thumb screws and disconnect one plug and lift off the document feeder.
The machine processor separates just above the tray 2/3 module, also the tray 2/3 module separates from the stand. So you can make is much easier to move by taking it apart. Nothing is bolted together, just sits one on top the other.
Jul 07, 2008 | Xerox WorkCentre M-24 Color Copier
149 people viewed this question
k24674
Marvin
Marvin
