Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have GE side by side fridge. The freezer built up frost and then started to defrost. I took everything out andoened the back panel. The freezer was getting cold again but frost on the coils. the fridge side is cold and the fan in freezer is working but freezer is full of frost again. What causes this?
  • GE Master
  • 1,606 Answers
Pull refrig out from the wall and unplug . Remove the 8" x 10 " panel covering the main control board . On this board , unplug the blue plug with 3 larger wires going to it . The sequence looks like this : wire1,wire2,space,wire3 . Use a piece of wire , with both ends stripped about 1/4 " , and insert an end into wire2 and wire3 . Plug refrig back in . Look inside the freezer at the back bottom , and see if you see a red glow . It may take about 30 seconds for the glow to appear . If no glow appears , the defrost heater located at the bottom of the coils ( glass tube ) is probably shorted . Pt # WR51X10042 . Also replace the defrost thermostat Pt # WR50X10068 . To access these parts , the inside freezer panel has to be removed . If you do get a red glow , then the main control board is bad Pt # WR55X10656 .
Posted on Sep 04, 2009
Testimonial: "Thank you very much for this imformation it saved me $75.00 which right now I really don't have. Unforntunately the board is bad. Thank You again"
    Problem Solver:
  • 10 Answers
U may have air getting in to ur freezer check door seals, also could be low in refrigerant check temperature in freezer with manual temperature probe
Posted on Sep 03, 2009
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
My refrigerator builts frost on the back panel, I've replaced the defrost heater three times. It works for a couple of weeks and then one side start to warm up while the freezer has frost on the back...
ge has had problems with the control boards, pull out the fridge,look on the back wall,unplug the fridge,remove the board and see if there are any burn marks on it the part number is WR55X10942 but check it with your parts store,give them the model number,i looked up the number you sent but they show at the end mbbs or mabs,mcbs so make sure you give them what they need
Feb 21, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 31, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
GE Eterna ESS25LGNA freezer side not working
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile side-by-side fridge and freezer not cooling properly
Could be a few things. Condenser coil clean? Is the back panel cover of the compressor panel in place? It could have a bad part in the defrost system and it's built up with frost on the coil. To see if this is the problem, unplug the refrigerator and leave the doors open for 24 - 36 hrs. then plug it back in. It should work normal again for a few days until the frost builds back up. If this is the case the defrost system needs repair.
Aug 21, 2009 | GE Profile¿ Arctica® Energy...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
your defrost timer is bad. this device is dual purpose, it is a small heater/solenoid that calls for the compressor to turn off so the lines can defrost (usually does it once every 48 hours or so). it looks like a round button clipped to the coil lines in the freezer behind the plastic paneling where the cold air comes out. you need to replace that part, which is actually very inexpensive compared to a new fridge. it will unclip from the coil line and the two or three wires will either disconnect or you may have to cut them and splice on the new ones from the new defrost timer. either way it is a job that will take anyone with basic hand tools less than an hour to do.
May 29, 2009 | GE GSH22SGRSS Side by Side Refrigerator
I have the same problem .i took apart the inside of
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over. Some manufacture designed kits to help and some home made remedies. http://www.applianceaid.com/defrost_drain_freezes.html
click the link given above
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Mar 02, 2009 | GE GTS12BBPLCC Top Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
290 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
