Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I need replacement blades for a Craftsman LT1000
    Sergeant:
  • 164 Answers
Get part # or model# from owners manual and go to sears.com and order or stop into a local sears with the numbers and theyll set you up!
Posted on Sep 03, 2009
5 Suggested Answers
  • 49 Answers
SOURCE: Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Posted on Jan 29, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
LT1000 917`274352 craftsman blades turn when starting mower
Sounds like the idler isn't releasing for some reason. Check that idler spring is in place and check that clutch cable as they tend to bind up as they get well used. Also the idler arm itself for binding.
Jan 17, 2015 | Craftsman Garden
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Craftsman LT1000 one blade locked up. What could be causing this?
You must remove the belt. The blade is attached to a shaft assembly that has a bearing on the top. Check to see if one or both is not free to rotate. You may need one or both of these parts.
All parts available on Sears.com.
Gary
Aug 27, 2011 | Craftsman Garden
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need a blade engagement cable diagram for a 2002 craftsman lt1000
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman lt1000 18 hp briggs keeps wanting to die
could be a dirty carb. Did you use stabil over the winter. Also could be a govener problem.
Jun 23, 2009 | Garden
Craftsman LT1000 Parts manual
find every part you need on amazon here Amazon com Craftsman LT1000 Parts . take a look and enjoy
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
3,851 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
