Question about GE Refrigerators
I have a GE Profile frig that we keep in our garage (where it is very hot since it is in Scottsdale, AZ). It was working fine, but about a week ago I noticed it was clicking and the lights in the garage were flashing in sync with the click. It was no longer cold, so I unplugged it and the clicking and light flashing stopped. I am pretty handy, but don't have any repair manuals, nor do I know if there is anything special I should be looking for. I can test electrical stuff, but don't have equipment to check freon levels / pressure.
  • eredleaf Sep 03, 2009
    So your solution says it is probably that my compressor is locked up which is causing the voltage drop. Are there any simple resets that might free it up (other than unplugging and replugging, which I have already done). Is there a visual check or and electrical check I can do on the compressor. I know that the compressor is generally the most expensive part in a refrigerator. This one is not very old, but it is probably out of warranty. Also since it was in the garage it is not covered by our home warranty. Once I open up the back of the frig what measurements should I take? Are there any parts to repair a compressor or do I have to replace the whole thing?
    This solution was a little helpful, but it was not complete as it didn't provide any advise on how to proceed other then unplug the refrigerator.
    President:
  • 1,723 Answers
What you saw is called 'voltage drop'. The cause, as you suspected was the fridge. What is happening is this; the compressor motor starts up to try and cool the fridge, it's probably 'locked up' or something. It's pulling high amps and the high amps flowing through your breaker panel to feed the locked motor is pulling the voltage down throughout the house. (because of the resistance in the copper conductors)
Leave the fridge unplugged until you can assess the compressor problem.
Posted on Sep 03, 2009
Have GE profile side by side frig and now the computerized panel on top keeps going off and on--this started when water dispenser stopped working
The control board located on the back of your unit is failing, the part you will need is WR55X10942, this part will run about 150 - 200 dollars. But this will fix the problem your having.
Jul 13, 2011 | GE Profile PSS26NGS Side by Side...
Can this GE TFX side by side be used as an extra frig in a garage that gets very hot in summer
most (not all) f/f can be used in ambient temps from about +5C to +35C,but use a seperate thermometer to keep the interior temps at +5C for a fridge and -18C for a freezer.
Oct 31, 2010 | GE GSH22JFR Side by Side Refrigerator
Frig freezes up after a few weeks -- the glass tube looks fine
THERE IS A DEFROST SENSO ON TOP OF THE EVAPORATOR MANY TIMES IT WILL LOOK SPLIT WHERE THE WIRES GO IN THE BACK IF SO REPLACE IT
Dec 19, 2009 | GE GSS22SGM Side by Side Refrigerator
GE Profile is Buzzing
Checx the wire connection and the way u food is inside ur frig. Maybe something is not at the right place!
Sep 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
REFRIGERATOR HEATS UP TO 90
gheck and see if your condenser fan working or pull the refrigerator 3/4 off the wall
Feb 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice keeps building up on coils
We had the same problem with our GE frig, a Profile 24. When the tech came out, he explained that the energy efficient models have only 1 defrost heater, but the older units had 2 and the hook up and mounting positions were still there. As long as I directed him to install the 2nd heater he could do it. It turned out the original heater was just fine, so the replacement was installed in the 2nd heater space and it has worked fine for several years now. Before doing this on yours, I would verify that the defrost timer is working and the heater unit is ok.
Jan 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side - Vegtable bin frozen and water not work
You may need service however you can try several pans of hot water overnight in the fridge, clean out the moisture and restart the next day. The problem may be solved.
Dec 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
