Question about Olevia Televison & Video
I have had an Olevia TV for about 18-24 months. The following information was taken from the back of my TV to get us started: M: Olevia--237-T12 Serial # (?): FM 1-037000KGo09 LCD HDTV--37 inches Recently, when watching TV, it plays perfectly as it has since I bought it. Last week we were watching TV when it cut off--the screen went black and no sound. I cut it back on and it worked fine. It's done that two or three times with no telling when it will go blank on me. Do you have any idea what could be causing it that I may share with a TV repairman? Thanks, Jim Langford je27332@yahoo.com
  • je27332 Sep 03, 2009
    My TV repairman as replaced a couple of electrolytic capacitors. It still cut off as I described earler. It might run 24 hours perfectly, but, then, it cuts off--screen goes black. I turn it back on and it works fine for an indefinite amount of time.
    je27332@yahoo.com
  • je27332 Sep 04, 2009
    Thank you for your advice on my Olevia TV: "...replace all electrolytic capacitors except main capacitors (big ones) that will solve the problem."
    My repairman is so doing.
    Question: what if this does not work?
    Thanks,
    Jim Langford
    je2733@!yahoo.com
  • 10,594 Answers
Problem seems in power supply board and most probably few electrolytic capacitors would be bad/ leaky/ weak in power supply that causing sudden shut it down and reboot.
Hope that will help to TV tech.
Thanks.
Posted on Sep 03, 2009
  • Shahid Electronics
    Shahid Electronics Sep 03, 2009
    If TV tech could replace all electrolytic capacitors except main capacitors (big ones) that will solve the problem. Another possibility can be lose connections/ dry solder joints in power supply board that needs to be re-soldered.
    Thanks.
    Shahid Electronics Sep 04, 2009
    problem."
    Thanks,
    Jim Langford
    Well last option is to replace complete power supply board.
Would like to use Direct TV remote instead of Olevia remote
Try the following steps:
1. Turn on the tv. 2. Slide the "Mode" switch to the "tv" position 3. Press and hold the "mute" and "select" keys at the same time until the green light under "tv" flashes twice. Release both keys. 4. Using the remote's keypad, enter the digits 9-9-1-1 5. Press "pwr" key. Point the remote at the tv. 6. Repeatedly press "channel up" key until the tv turns off. 7. As soon as the tv shuts off, press and release the "select" key Your remote should now be programed to the tv.
All of this information came from the link below. If you have any more questions, this link may be able to answer them for you:
www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC64forWeb.pdf
Thanks for the question, and good luck! Sincerely, Der Strom
Apr 12, 2010 | Olevia LT37HVS 37 in. LCD HDTV
TV is not coming on anymore
power supply issue whats the model and i will try source a psu and price
Sep 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 37 lcdtv has to warm up be repowere for picture to display
It's your power supply. have it taken care of ASAP before damage happens on the board where it can't be repaired, just replaced, "if they can find one".
Jul 15, 2009 | Olevia 237T 37 in. LCD TV
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
SYNTAX OLEVIA LT30 POWER SUPPLY
Yes they are bankrupt, and they did see repair services out to third party vendor- this appears to be phone support at $25 per 1/2 hour.
email response from service inquiry....
Thank you for contacting us. My name is Ravin and I understand that you have called in today for further troubleshooting but you were offered a paid service instead. Based on the information provided, I believe that the following steps should effectively resolve the issue:
I am sorry to inform you that, Syntax-Brillian, the manufacturer of the Olevia Brand, has declared chapter 11 bankruptcy and has ceased all operations. Because Syntax-Brillian is no longer in business the warranty for your product is void.
Amergence Technology, a 3rd party repair company, can offer paid repair services for your television and a paid service for further troubleshooting. Since Syntax-Brillian went out of business, Amergence is offering repair services to owners of Olevia HDTV's.
If you have any further questions or concerns, please do not hesitate to contact our Support Team at 866-965-3842 Monday through Friday between 7.00am 5.00pm PST
Sincerely,
Ravin
May 11, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have an Olevia tv model 437-S11 that won't power up.
Hi there
I solved my problem by downloading new software from I can't remember the website (it's been about 5 months) and loading it via USB cable. I can't believe it worked but it did. You should try Google search and look for troubleshooting tips for your tv. Include model and serial numbers. When you download new software make sure you have the correct software version and find and follow directions as to how to get it done. Let me know if it worked for yah...Good luck and a happy new year.
Dec 30, 2008 | Olevia LT23HVX 23 in. LCD Television
My 42" olevia hdlcd will not power on. the green lcd is on howev
main board problem olevia has that problem look up olevia parts go there you might be able to find a mainboard for it and from here on never buy olevia the support sucks and very high to buy from these tv s know some how warranty is up and go out they are very easy to work on
Olevia customer service
OLEVIA tV is a F#$King JOKE!!!!!.....I bought my tv in Jan and it went out 3 months after that, let me put it to you like this its Oct and i havent got my tv back to this day.
Got a case number and a tracking number that didnt make any sense. The shipping company they used didnt get paid so its been in there storage for 3 months. In some way if you have been waiting for your tv because of the shipping...Olevia is responsible for trans issue and pulling off on the shipping company.
OVERALL
DONT BUY A OLEVIA TV..... YOUR BETTER OFF WITH A LG!!!
Sep 28, 2007 | Olevia LT42HVi 42 in. LCD Television
SHARP,PIERCING, ALARM LIKE NOISE COMING FROM TV
unhhok all the sources from the tv as to eliminate where it might be coming from, hook up one source at a time you might find the problem that way
Oct 20, 2006 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
75 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
