Question about Coby TF-DVD7006
The p/n 002-fd70-06k3-00R overheated and damaged several components on this board. Where can I find a replacement board, and what could have caused the overheating ? chuck
  • 157 Answers
I GET ALOT OF PARTS FROM shopjimmys.com they sell alot of flatscreen parts
Posted on Sep 03, 2009
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpa
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Sensor goes off inside microwave after 10 seconds
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 03, 2012 | GE Microwave Ovens
Set clock but time goes off
Oct 02, 2012 | Viking VMOS200 Microwave Oven
Alarm list says motor rotation and cuts off
Sep 27, 2012 | Microwave Ovens
TV will not come on
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr. and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Sep 10, 2011 | RCA D61130 61" Rear Projection Television
Our Schneider Altiver 71 drive power board was damage. Can we repair that part?
Eh, The power board is modular in design and as such is easily replaceable. Repairing the failed component, may get it running again, but it is hard to tell whether the life of the other components have been compromised. Check you warranty coverage. In the least, if you buy a replacement, you should be able to get a warranty with it, in case issues arise again. Try to determine if the failure was due to incorrect voltage or overheating. Your unit is equiped with thermal protection. See if perhaps that protection failed and caused the damage to the power module.
Good Luck!
Jun 20, 2011 | Garden
Power light is flashing- tv wont turn on
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem (such as the high voltage supply) is causing an overload.
Nov 26, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Monitor comes on,then goes off after a couple of seconds.Checked the circuit board but found no problem,feel that the screen might be faulty,please help.
This could indicate some component overheating/damaged. I haven't worked on a monitor like yours, but on several occassions I noticed that the problem was caused by blown capacitors. This can usually be spotted if you inspect the capacitors on the logic board carefully. If they are bulging or you can see black goo "leaking" from them then they need replacing. Other than that, troubleshooting of other components on the logic board is far too complicated to describe here.
Hope this helps,
Raf
Nov 13, 2009 | Soyo Dymond DYLM017A 17" LCD Monitor
TV turns of automatically
could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components. good luck
Mar 26, 2006 | Sharp 27C-240 27" TV
Picture on screen wont stay on
Mar 26, 2006 | Sony KV-35S42 35" TV
Coby TF-DVD7006 Logo
76 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
