Question about Ovens
HC-590 TEKA OVEN
When switching oven on fan working light on front panel no heat at all, but get heat when using grill of the oven
Need help urgently to solve this problem
3 Suggested Answers
  • 12 Answers
SOURCE: Teka Model HC-595 - oven does not heat, fan
Sounds like the fan element has blown. I think access is from inside the oven at the back BUT the screws to undo the element are accessed by removing the rear cover. You will have to take the oven out of the cabinet to where is is fitted to do this and from memory there is an earth tag which is fixed to one of these screws
Posted on Oct 22, 2009
barkencoa
  • 3463 Answers
SOURCE: i have a Teka oven
If the fan is working o/k, then it is probably the oven element that is faulty, usually located at the rear of the oven compartment behind a removeable cov er.
Posted on Oct 21, 2010
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
Indesit cooker
I would contact indesit on there tech help line .Its on line on there site
Apr 21, 2017 | Ovens
I have a Teka oven HI-595 that shows power, fan works and grill works but oven won't heat up. What should I do?
Oct 21, 2010 | Ovens
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Teka h e 500 oven wont heat up....
If the fan is working o/k then the oven element is probably faulty, this should be at the rear of the oven behind a removeabkle cover.
Make sure you have the control set to grill , for grilling
Dec 03, 2009 | Ovens
Teka Model HC-595 - oven does not heat, fan working ok grill working ok
Oct 19, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
No heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Jan 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Ovens Logo
123 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
