Question about Thomson Computers & Internet
I have a Thomson ST516 v.6 modem that I am trying to install. The set-up wizard does not detect a connection. I have a valid IP address. All of the cables have been connected properly. It's turned on and fully initialized. The ethernet light is blinking. There's no personal firewall software running. I've tried re-setting the speed touch. Any suggestions for what more I could do?
    Scholar:
  • 50 Answers
Most of the times is a wrong username / password issue.
most people forget the @ after the username.
for example my username is "jimmy" but in the modem i should enter: jimmy@otenet.gr because otenet is my provider... if i was on forthnet i should write jimmy@forthnet.gr etc.
the easyest way to fix this is to call your providers helpdesk. they can see in their computers if you are connected or not and check your username or password and many other technical things that can help you solve this.
Posted on Sep 03, 2009
I have a DHG536C Cable modem from Comcast. I am using a Linksys Switch, EZS88W, and the modem can see one computer but nothing eles, what is wrong?
Have you connected all computers, then switched off the switch and modem. now switch off your computers.
If you then power everything up, it should detect the computers, and assign them the correct IP addresses.
If your still having problems, you may need to assign static ip addresses (google for instructions for your computers/switch)
Sep 14, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
RCA DCM425 modem ethernet connection won't work
The setting for the Computer 1, use the network connection wizard to automatically configure the modem to work as a server station. Next, set the IP number manually and the DNS at automatic or is given by your ISP. Now the Computer 2 (workstation) should be connected to a Hub/Switch. The same, go to network connection wizard and select the appropriate connection setting, there are view samples for the connection types so explore them. After the setup, try loading your internet browser.... When done, it should work fine. Keep me posted for any problems.
Nov 26, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Set up with Mac G-5 and RCA by Thomson digital Broadband modem will not connect through Netger WGr614 Wireless Router
For Set-Up Procedure follow these steps:-
1)Connect the Modem to the Internet port of the NETGEAR router and the computer to any of the four LAN ports.
2)Open an Internet Explorer browser and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 in the address bar and press Ente
The Login window will prompt for the router configuration username and password.
The default username is “admin” and
the default password is “password”
3)Click Setup Wizard on the top left corner, Select Yes for the Setup Wizard to detect the type of internet connection and click Next.
4)The Setup Wizard will detect the type of Internet connection. For Cable Internet connections, Setup Wizard will detect Dynamic IP. Click Next
5)You do not have to change the default settings unless your ISP has given you specific DNS information which must be configured so smiply without changing anything click apply.
6)The router will now save these settings. When complete, you can verify whether you are connected to the internet from the Router Status > Maintenance menu.
7)Under Router Status you will have Internet Port , If you have the Ip Address Under Internet port you will have the wired connectivity then.
Link:-http://kb.netgear.com/app/answers/detail/a_id/119
Wireless Connectivity Steps:-
On the left hand side you will have the blue/purple column in their under the category you set-up you will see a sub-title wireless setting's, left click on that option and then do the setting's.This link will guide you how to do that:-
http://kb.netgear.com/app/answers/detail/a_id/112/related/1
Steps for Wireless Connectivity on MAC:-
1)Click on the apple icon on the left hand side of the start screen and go to system preferences.
2)Under system preferences a category name internet and network select the title network from there.
3)Under Network you will have an option for airport to turn it ON so do that and then below you will see list of networks available , from that list select the network you created , enter the password if it's secure one and you will be good to go from ther on and will have an internet access.
Nov 19, 2009 | NetGear WGR614 Wireless Router
Hi, i have wnr2000 and am trying to set it up. i'm at the setup wizard which says that i already have a valid internet connection. what does this mean and what do i do next?
Basically you need to sign up with an Internet Service Provider in your area. The ISP will advise you the type in modem/Internet connection you need for their service (ie. DSL or cable) and advise you or provide you with a compatible DSL or cable modem. The ISP will provide an installation disc or instructions to configure the modem so it connects with their Internet server.
The modem is then connected to the wnr2000 router's Internet/WAN port with a LAN cable.
If you have already configured the modem and connected it to the wrn2000 router and the setup wizard has detected that you already have a valid Internet connection (it has detected your TCP/IP address which your Internet Service Provider has given you - this IP address is your unique network address - it is similar to your house address in your street, in your suburb, in your state, and in your country). Just click OK and continue with the setup.
Oct 30, 2009 | NetGear WNR2000 Wireless Router
I HAE A NETGEAR WGR614 AND BSNL MODEM MT882...NOW THE THINGIS MY MODEM IS NOT ABLE TO MAKE THE PPPOE CONNECTION BECAUSE OF WHICH MY ROUTER IS NOT INTERACTING WITH THE MODEM AND THE CONNECTION ALWAYS COME...
Hi dude,
Make sure that you can go online through the modem when connected directly to your computer.if yes, then please perform the steps below on the router to configure settings;
1. Connect a ethernet cable from the Modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Open the browser(Internet Explorer or Mozilla Firefox).
4. Access the router settings with the address: www.routerlogin.com/basicsetting.htm
5. Whenever prompted for username and password please enter User Name as 'admin' and Password as 'password'.
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and Click next.
8. In case you get the message: 'You already have a valid internet connection do you still want to continue', click 'YES'.
9. It should give you either a "Dynamic IP Detected" or "PPPoE detected".
10. If you get "Dynamic IP Detected" click on 'Next'. On the next page select 'Use Computer MAC Address' under Router MAC Address' and click 'Apply'.
11. If you get "PPPoE detected" click on 'Next'. Enter the login name and password provided by the ISP. Click Apply.
12. From the left menu go to 'Router Status' and check if you get the internet port ip address.
13. Click on 'Logout' (at the bottom of the list) from left menu.
14. Open up another browser window and try to access internet.
if you still have issues. then please connect the modem direclty to the computer and perform the task below:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here. Also, mail us the same IP configuration.
This information will help proceed to the next step
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 08, 2009 | NetGear WGR614 Cable/DSL 54 Mbps 802.11g...
Installation manual for router RP614v4 lost. need help in setting up router or manual.
To configure the router follow the steps below:
OR download the manual frm here:
http://kb.netgear.com/app/answers/detail/a_id/2153
Jul 03, 2009 | Computers & Internet
Just purchased, trying to set up. Having problems
Hi, follow the steps below to configure the router:
Jun 30, 2009 | NetGear RangeMax WPN824 Router
Thomson router
dsl signal / light on modem ..ok
connection to computer ..ok
able to log-in to the internet service provider ..ok
check your IP address setting on the computer, must be set to automatically get IP address, same goes for the DNS setting.
Oct 04, 2008 | Computers & Internet
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Computers & Internet Logo
311 people viewed this question
Top Thomson Computers & Internet Experts
jimmy Leo
Raj Patel
Wbix
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
