Question about Texas Instruments Office Equipment & Supplies
HOW TO INTER FRACTION ON A TI-83 - Texas Instruments Office Equipment & Supplies
  • Texas Instru... Master
  • 8,025 Answers
Once you enter a fraction the calculator calculates it and displays a decimal result.So basically you cannot do fraction manipulations. However you can convert a decimal result into a fraction. To do the conversion, you enter the decimal number then you Press [MATH] and [1]. ( -->Frac) The number will be converted.
Similarly you can enter a fraction to a decimal number (-->Dec)
[MATH] [2:] [ENTER]. But I see no point in doing that, because any fraction entered is displayed as a decimal number.
Hope it helps
Posted on Sep 04, 2009
  • k24674 Sep 27, 2009
    Addendum. There is a way to enter a fraction and have it reduced to its simplest form without converting it to a decimal number. Ex: 27/48 can be reduced further by dividing both elements by 3. To enter the fraction Press 27 [/] 48 [MATH][1:->Frac][ENTER] the screen displays 9/16.
    So if you want to calculate with fractions and obtain results as fractions, insert the [MATH][1:->Frac]. Exemple 27/48 [x] 5/13
    (27/48) [x] 5/13 [MATH][1:->Frac] [ENTER] gives 45/208.
My ti-83 stop changing decimals to fraction
The Frac command only works if the number can be expressed as a fraction with no more than three digits in the denominator. Since the square root of 5/9 is an irrational number, it cannot be expressed as a fraction at all. The calculator is telling you that the value cannot be adequately approximated as a fraction with three or fewer digits in the denominator.
Jan 14, 2013 | Texas Instruments TI-83 Plus Calculator
I'm trying to find the fraction button on my texas instrument ti 83 plus calculator and cannot find it
There is no "fraction" button on the TI-83 plus. You will have to press the divide key (2 buttons below the CLEAR key) and then use the parentheses (immediately to the left of the divide key) to tell the calculator the correct order of operations. For example, "1/3x+9" means ".333333x+9", but "1/(3x)+9" means the "x" goes on the bottom of the fraction.
Jan 18, 2011 | Texas Instruments TI-83 Plus Calculator
How do you put a fraction into a TI-83?
The TI-83 doesn't really work with fractions. You can enter a fraction as a quotient. For example, one-third can be entered as (1/3) by pressing ( 1 / 3 ). However, the calculator works with numbers in decimal format. You can convert a result to a fraction by using the >Frac command, available by pressing MATH 1.
Nov 03, 2010 | Texas Instruments TI-83 Plus Calculator
How do I get a fraction as an answer instead of a decimal?
The TI-83 can only convert a small range of numbers to a fraction. To try so, use the >Frac function on the MATH menu. Press MATH 1 to invoke it.
Oct 25, 2010 | Texas Instruments TI-83 Plus Calculator
How do i multiply fractions on texas instrument TI-83 calculator
The division sign acts like a fraction on the ti-83; to multiply two fractions you may want to wrap them both in parenthesis to get the order of operations correct.
Vote early and often
Sep 24, 2010 | Texas Instruments TI-83 Plus Calculator
Fractions on my texas tI-83
You get access the command by pressing [MATH][1: |->Frac].
If you want enter a fraction and keep it as a fraction (albeit a reduced one)
key in the number then the sequence [MATH][1: |->Frac]., then [ENTER].
Practice : 27/48 [MATH][1: |->Frac] [=] gives the reduced form 9/16.
While this fraction is still in [ANS] memory, you can press [MATH][2: |->Dec] [=] to get the decimal value 0.5625
Hope it helps.
Nov 01, 2009 | Texas Instruments TI-83 Plus Calculator
Where is the fraction button on the ti 83 plus cac. look like
There is no fraction button. Any division of two integers you do is represented as a decimal number. If you want your fraction to remain a fraction you enter it as follows
7[ / ] 19 [ MATH][1:ToFrac] [=] displays 7/19
If you want to convert a decimal number into a proper fraction press [MATH][1:ToFrac] .
Exemple 7/19 [ENTER] gives .36842105. If without doing anything else, you press [MATH][1:ToFrac] you recover 7/19.
There are limitations related to the number of decimal digits in the floating point number.
.3684 [MATH][1:ToFrac][=] gives 921/2500 but
.36842 [MATH][1:ToFrac][=] gives .36842 : it is not converted to fraction.
Hope it helps
Sep 16, 2009 | Texas Instruments TI-83 Plus Calculator
What do I do to get the fraction 5/8 on my TI-83 Plus calculator?
Just put in (5/8) and that will tell the calculator to that first then when done with the problem you press {math} then press {Frac} and it will give your answer back in a fraction
Aug 21, 2009 | Texas Instruments TI-83 Plus Calculator
How to write a fraction on the TI 83 plus
FIRST THE NUMBER YOU ARE DIVIDING EX. NUMERATOR DIVIDE SIGN DENOMINATOR THEN TO GET TO THE LOWEST COMMON DEMONINATOR GO TO mATH BUTTON WHEN SCREEN APPEARS YOU WILL BE IN FRAC. HIT INTER. GLENDA
Jun 04, 2009 | Texas Instruments TI-83 Plus Calculator
635 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
