Question about Xerox Office Equipment & Supplies
WAX INK STUCK IN A XEROX 8560 MFP - Xerox Office Equipment & Supplies
    Scholar:
  • 118 Answers
If you lost power or unplugged this unit without first allowing it to perform a full shutdown, you are most likely seeing the wax ink 'dumped' internally. You'll need to contact a certified Xerox technician in order to get the unit cleaned and repaired.
Posted on Sep 04, 2009
No display
You probably have to replace the display. It is a common problem.
Oct 19, 2014 | Xerox Phaser 8560MFP/SN - 30 PPM...
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
My xerox phaser 8560 MFP is showing system error 09,037.45:54135 and I can't figure out how to fix the problem.
Ink count flag stuck after melting 2.5 Yellow Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Step 1.Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
This must be performed following an ink loader replacement.
Step 2.Test the appropriate Ink Melt Heater.
Run the Service Diagnostics Ink Melt [1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Yes)Replace the Printhead
No)Replace the Ink Loader
Aug 03, 2011 | Office Equipment & Supplies
Could tell me what is the following code : 09,035.43:62287 on phaser 8560 mfp. please
Ink count flag stuck after melting 2.5 Cyan Ink Sticks.
Initial Actions
1. Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks. Are the Ink Sticks loading properly?
Yes)Go to Step 2.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error.
2. Test the appropriate Ink Melt Heater.
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
• 4 = Black
Did the test pass?
Aug 03, 2011 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 MPS System Error Press (?) 09,038.46:1252 Help Me Please... oolivas@gruposion.com.mx cvalabacillascity@hotmail.com
The ink-loader is defective and probably needs to be replaced.
The MFP ink-loader is unique, so you must buy PN 848K06380
Whit
Item, Inc.
Sep 13, 2010 | Xerox Phaser 8560MFP Laser Printer
Error code 09,035.43:30419 on Xerox Phaser 8560
Check your ink sticks, one of them is most likely stuck.
Dec 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 died after installing new maintenance kit.
The error is caused by the printhead not being able to tilt, the maintenance kit (oil roller) is driven round by the drum and has no physical connection to the tilt mechanism. Having said that I did once have a machine that had waste wax loose in the machine and when the customer replaced the maintenance kit the loose wax was pushed into the tilt drive gears which are located on the inside frame left hand side, right behind the oil roller. The wax jams the gears making a noise like a machine gun and tilt error 07,010 was the result.
Oct 21, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 8560 is very hot even in sleep mode
the fusers get about 300 degrees to melt the toner to the page. If you do not have the phaser clean regularly, the paper dust that is next to the fuser could smell like it is burning.
Jul 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
114 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
