Question about Refrigerators
Freezer is very cold evap motor blowing however,the refrigerator will not go below 42degrees
  • Wayne Holden May 11, 2010
    Evaporator motor is blowing, where? Do you feel any air being moved into refrigerator?
    Champion:
  • 239 Answers
Defrost the freezer
Posted on Sep 03, 2009
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
Frigidaire refrigerator model # frs6r5emb8 wont get cold and freezer wont freeze. I replaced the filter and cleaned any and all dust out from the rear bottom of the refrigerator. Freeze wont get cold...
first off the freezer is cold but not cold enough?if the freezer isn't working right then the fridge is gonna be warm too,all it does is get cold in the freezer and the evap fan blows cold air into the fridge,that's it.i need you to do a few checks for me,open the freezer door,do you hear the fan blowing around,if not you could have a bad evap fan motor,next from the bottom up remove the second bin from the bottom and touch the back wall,do you feel any ice or snow on the back wall.if so you have a defrost problem,possible computer board,defrost thermostat or heater.let me know what you find.one more thing did this happen after you cleaned it or did you clean it to try to see if it would help?
May 15, 2011 | Refrigerators
Refrigerator not cold - freezer ok
all a fridge does is blow cold air from the freezer into the fridge section,so you could have a bad evap fan motor,when you open the freezer door you should hear the fan blowing air around,the air ducts could be frozen from the door being left open,common on bottom freezer machines or if it has a damper in it the damper door could be stuck closed,next time when you ask a question you have to send the model number and brand name so i can help you better.
May 13, 2011 | Refrigerators
Fridge side not cooling i have unplug for a minute and plugged back in starts fine and then i hear a click sounds like compressior is running but not getting cold
first off what is the brand name and model number?is the freezer cold?if so when you open the freezer door do you hear the fan blowing?all a fridge does is get cold in the freezer and the evap fan blows cold air from the freezer to the fridge side that's it,if you don't hear the fan when you open the freezer you have a bad evap fan motor,but send more info.
Apr 09, 2011 | Refrigerators
Refrigerator is not getting cold
the evap fan motor sounds like its not working . replace the fan motor and the defrost terminator .. ..mm
Jul 01, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator compartment is warm around 20 centigrade and have foul smell. Freezer is OK.
Hi!!
Have you checked the temp. controls? Sometimes they get moved by accident.
The next thing to inspect is the freezer fan motor. This motor is the one that blows cold air from the evap. in the freezer to the fridge compartment.
If both things are OK, have the fridge serviced asap.
Good Luck!!
Mar 15, 2010 | Refrigerators
Refrigerator is not getting cold although the freezer appears to be working fine
can you hear the evaporator fan motor running in the freezer? this fan motor pushes the cold air from the freezer to the food section to keep it cold. you may have to replace the evap. fan motor. also, check for any kind of ice build up around the evap fan motor.
Oct 11, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator not cooling properly
evap. coil could possible be frosting up due to a defrost problem, this would keep the evap. fan from blowing air into ref. section. it also could be a bad evap. fan motor or it could be that the ref. inside light bulb could be staying on due to a bad light switch ,you would be surprisedhow much heat a 40 watt bulb produces
May 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
