Question about Kenwood VR-407 Receiver
MY KENWOOD KR-X1000 RECEIVER SHUTS OFF RIGHT AFTER I TURN IT ON. CLIP LIGHT SHOWS BEFORE SHUT OFF
3 Suggested Answers
  • 979 Answers
SOURCE: KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Posted on Oct 25, 2007
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
How to connect spekers
If it's your first time in this project, connecting speakers are not simple but you can learn fast. First of all, I don't know the type of speakers you have. Not all speakers are the same, even in sound they're not the same. Some sound superb, others sound just right and many sound like tin cans. Because you have a Kenwood KR-X1000, it looks like you have large speakers. To connect these large speaker you need high quality speaker cables, not cheaper low amp types. Cables for speakers are usually marked with a continuous colored line along one side the cable. This line is an orange color is the cable is 100% copper and is a clear plastic cable (you can see the braided or twisted wire inside), or it could be black plastic with a white or grey colored band on one side of the cable. The colored bands means it's positive side (+). Split the cable ends then splice about half inch and twist the exposed wire. If you have a soldering iron, solder the exposed twisted braids to make it into a single solid wire for easy insertion into the speakers.
Now, I don't know what speakers you have but it doesn't matter, as long as you are aware that there are three types of connections used to connect the wires to the speakers. One type is a snap-on, another type is a squeeze, insert the wire in and let go. This is like a clamp. Another type is the a bolt type with a hole in the shaft of the bolt. The head is usually a plastic but to hold the wire and it is the strongest. Let's say you have the bolt type used by many professional speaker makers and users. You simply unscrew the plastic nut until the hole is open, then insert the wire in the hole then screw the plastic nut back tight. do a light pull test to see if the wire might slip out. Remember that these speaker connectors are colored red and black and the wire with the colored line on sheath is positive, that is it goes into the red connector. Then on the other end of the cable bet some tape or a tie to say this is the left speaker and this is the right speaker, this is the rear speaker and this is the right speaker, so that when you connect them to the Kenwood, you will not have to check which cable goes where.
The same thing goes with the Kenwood wire connection. I am a Pioneer man, I know them well. But I just happen to know that Kenwood and many others are very similar in wire connections because I am close to a store that has these, so, it's easy for me to go there and learn the tricks of trade. However, when I was writing this, it was too late to go down and have a look and the Kenwood X1000. So, I can only say that if you looked behind the machine, you'll find it all easily set and you can't go wrong. The red is positive (+) and black is negative (-). If you have been able to wire the speakers as instructed above, then you are also able to wire the Kenwood amplifier. Split the cables and strip or splice a half inch to expose the stranded wires the twist them and solder to form a solid wire for easy insertion and to stop the little copper wires in the braid from separating themselves from the twisted group. Then insert the colored line of the cable into the positive (red) clamp, clip-on, or screw type connector, whichever your amplifier has. Insert the negative soldered wire into the black clamp, clip-on or screw type connector. Do the same with the others speakers wires, recheck the connections, paying attention to polarities and test. It should work without problems. Cheers.
Dec 15, 2014 | Kenwood KR-X1000
My problem is i not can connect the speaker
Refer to the manual(s). Your unnamed speaker(s) may have special requirements (or not). Either way, the manuals are very helpful and a good place to start.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-X1000-Receivers-manual/id/479dj792/t/2/
Mar 24, 2011 | Kenwood KR-X1000
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
Same problem with KR-A46
Hi all,
may I ask if anybody solved the station memory problem
with Kenwood KR-A46. I do have the same and I dare to fix it
but I am looking for the right solution.
Thanks!
Ralf
May 22, 2008 | Kenwood KR-A5080 Receiver
My Kenwood KR-V5570 receiver powers off when I try to run a medium to high volume and the standby light blinks
i had exact problem.
the bare wire speaker cables that connect via a clip connecor in back of the receiver are pushed too far in. something inside is shorting out with the speaker cables. solve this issue by either tightly twistng or soldering the wire ends ( then clip the ends about 1/4 inch long). watch out for the same issue of electrical shorts at the speaker end of the cables.
Apr 27, 2008 | Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
Oct 25, 2007 | Kenwood KR-X1000
Kenwood VR-407 Receiver Logo
180 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
