Question about Hitachi 42HDM12 42 in. Plasma Television
Green vertical line on right side of my 42"hd hitachi plasma
Tech said it could be the panal or board, either way it will cost hundreds if not more to fix, better off buying a new tv. my tv is olny 4yrs old!
  • 63 Answers
You need to replace the ABUS-L-PWB on the left side about $75 for part.
Posted on Sep 03, 2009
Pioneer Elite Plasma vertical lines
Check for any loose connection at the COFs. Contact any service technician. If you wish to get some details, http://electronicshelponline.blogspot.com/Pull up older posts. Defective screenshots to plasma are shown. You can compare it to that of your TVs'.
Dec 21, 2013 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Black vertical strip on Hitachi plasma
seems like a lose ground issue from the vertical scan board which usually causes this problem. A scan board repair or replacement should fix this intermittent problem.....take it too your local repair shop before this problems spreads and the tv totally shuts down....
Nov 03, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
I have black vertical lines in the middle of the screen, what could be causing that?
You have a bad circuit board causing this.
Call a good TV Tech for an estimate. You should call your local BBB before deciding on one.
Aug 03, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41A Turn On with white and yellow vertical lines
you have to replace the vertical sweep IC and check the voltage across its VCC. If you cant understand tech words, better visit the service center.
Jul 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Black vertical line on screen
this tv has 3 drive boards at the bottom of the tv, inside the back, hard to get to them, there is one in the middle , and one on each side, they usually cost arount 100 dollars, the drive board below where the line is, has probabily gone bad, but about 20 percent of the time, you can undo the ribbon connector where the line is, and reconnect it, and sometimes it will fix it,
Jan 09, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Hitachi tv
call tech ..suggest logic pcb.
Nov 26, 2007 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Hitachi 42" Plasma 42EDT41
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!  Even if you decide not to attempt it, it gives you somewhere to start to tell a technician.
Aug 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
371 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
