Question about Sony Walkman NWZ-B105F MP3 Player
Nwz-s639f stuck on hold
My nwz-s639f is stuck on hold. The main menu screen is displayed but use of the play or tabbing arrows just evokes a message "On Hold - Cancel Hold function to activate controls". It is not possible to turn the player off. If the battery runs out, the problem just recurs on recharge.
When connected to a PC the PC can see and access the player.
Any ideas how to fix?
    Problem Solver:
  • 5 Answers
Try reseting it if theres a way you can. or if theres a hold button
Posted on Sep 03, 2009
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
How do I clear the memory on the player?
To clear the Memory of the Walkman Player, try formatting it with the Menu items.
The Steps to format the Player is, 1. Press and hold the BACK/HOME button in the pause mode until the Home Menu appears. 2. Press arrow keys to select "SETTINGS" and press the Playback/Pause button to confirm. 3. Press arrow keys to select "COMMON SETTINGS" and press the Playback/Pause button to confirm. 4. Press arrow keys to select "FORMAT" and press the Playback/Pause button to confirm. 5. Press Up/Down arrow keys to select "YES" and press the Playback/Pause button to confirm. "All Data will be deleted" Proceed? message appears on the display. 6. Again, press Up/Down arrow keys to select "YES" and press the Playback/Pause button to confirm. Now, Memory formatted message will be displayed.
I hope you find this information useful. Thanks,
Pradeep
Nov 18, 2010 | Sony Walkman NWZ-S616F MP3 Player
Im trying to adjust my philips lcd but menu says "osd main control is locked" how can I unlock it?
In order to resolve the OSD menu locked error:
1. You must reset the on screen display in the menu.
2. Hold down the Menu button for at least 60 seconds.
3. A menu list will appear on your monitor screen.
4. Using the adjust button, press the arrows to enter the menu.
5. Scroll down to the Reset section.
6. On the right side of your screen, you will see an alternating Yes/No choice.
7. When the Yes message flashes, press the Ok button.
8. The menu should be reset and the flashing OSD control message should disappear.
Apr 12, 2010 | Philips 190B6CB/27 19" LCD
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Sony Walkman NWZ-S639F will not connect to PC running XP.
Yes I had the exact same problem with both Norton 2009 and TalkTalk Super Secure Boost. To solve it you need to go to control panel, switch to classic view, scroll down to 'System', in System select the tab 'Hardware', then click on 'Device Manager', then click on WALKMAN NWZ-S639F and go to update driver. This solution has solved this problem for me twice, should solve your problem too, let me know if it does. Thanks
Jul 06, 2009 | Sony Network Walkman NW-E005 MP3 Player
Lg Dare phone
Leslie,
I had purchased and am currently using the LG dare. The issue that I had with the icons apprearing on my main screen was that I was accidentally holding down and dragging the icons from my shortcut menu to the main screen. The easiest way to get rid of the icons from the main screen is to hold down the icon and drag it to the little arrow for the shortcut menu, and it should dissapear.( I just did it on mine so it should wok for you).
If that doesn't work, open you shortcuts menu, hit the set button and remove the icon from the shorcut menu (this should remove it from the main screen as well.)
good luck!
Nov 16, 2008 | LG RUMOR Cellular Phone
Sony Walkman NWZ-B105F MP3 Player Logo
578 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
