Question about Siemens Electrical Supplies
Have a heating timer type RWB9, keep getting ''limit'' coming up even though I have reset the timer many times over . Question :- Has the the timer got a malfunction ?
Have replaced the switch
Posted on Sep 04, 2009
Who have purchased 2 (actually 3 but the other one was a different kind) utilitech 0050024 outdoor timers and both keep resetting to midnight on monday as of the power has gone out. All programmed info is...
Sometimes people get batches of bad timers.
However this timer does not show a program carryover, and does not appear to have battery for carryover. Although many new timer have a capacitor backup, it is unclear if the Utilitec offers this feature.
http://waterheatertimer.org/pdf/Utilitec-0050024-tower-stake-manual.pdf
Use reset button to clear memories, and then reprogram.
This timer has 2 modes: programmable or photocell
As a general rule, these timers come with 1 year limited warranty, but unclear who backs Utilitec warranty.
Buy two new timers from different Lowes store, and return defect in new package.
Jun 12, 2013 | Hardware & Accessories
The display has gone blank on T1033 . the only way to get towel rack to work is by pressing the on/off selector
1) Try resetting timer. Aube/Honeywell TI033 7-day 2400watt timer cannot be exposed to temperatures below freezing, even though manual says -5 F. High temperature range is 122 F .
This timer has 3-year limited warranty. Internal battery is non-replaceable.
http://waterheatertimer.org/Aube-timers-and-manuals.html
2) There is no other programmable in-wall timer that can handle 2400 watts without using contactor.
3) Replace with GE 15132 timer for cold environments, and single-pole or 3-way operation: Use contactor for heavy loads.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump22-28.jpg
4) Add comment as needed
Dec 28, 2012 | Hardware & Accessories
Stanly outdoor power center keeps turning off
Try unplugging timer.
Plug timer into different outlet.
Do not plug into extension cord.
1) Copy following link to identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Stanley power center, is made by Westinghouse and has robust 1 year limited warranty... but unknown who honors the warranty.
3) There is no reset protocol for this type timer.
4) F setting is permanently OFF.
If you can manage to get the timer to O, then plug yard stake into a cheap wall timer. Then use the cheap timer to replace yard stake timing.
5) Yard timers are made to last a couple seasons, and some do not work at all.
Dec 19, 2012 | Hardware & Accessories
I have a newlec timer channel plusxl model nlh37 unable to programme it after it was switched off, all heating systems running at same time
1) Power surge such as turning power ON can put out timers.
2) Reset timer, and if functionality is not restored, then replace timer.
3) These timers usually have 1 year limited warranty.
4) Add comment and include photo of timer. And post your .pdf manual on your website, and include link to manual so timer and steps for reset can be ascertained.
Dec 13, 2012 | Hardware & Accessories
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Installing the battery can't get the door opened to insert battery
Drawer pulls straight out. Use small screwdriver or metal nail file.
Copy following link for illustration and CR2 battery, and ez-to-follow programming, and wiring options.
http://waterheatertimer.org/images/ST01C-program.html#battery
Remember the drawer is also 'plugged' into the timer, so do not bend small metal prongs on drawer.
This timer comes with 1 year limited warranty against defects in workmanship.
The battery operates timer functions, so once battery is installed, the timer can be programmed before timer is installed in wall.
Be sure to reset timer before programming to eliminate stray code on the memory chip.
Once timer is programmed, the programs remain inside memory chip forever, even with power loss and no battery, until timer is reset of re-programmed.
Reset this timer: Hold down on-off button and momentarily push round reset button with paper clip. Keep holding down on-off until display changes, then release on-off button and begin setting current time and programs.
Nov 27, 2012 | Intermatic & Self-Adjusting Wall Switch...
Moisture control
Dryers have 2 basic types: AUTODRY and Electronic. The electronic moisture control relies on 2 bars inside the dryer. As wet clothes rub these bars the wetness discharges the capacitor on the moisture control board. As long as the cap don't get a full charge the timer motor will not advance forward to the end of cycle. What goes wrong on these? Wax buildup on moisture bars form a barrier that keeps wetness off them bars. The control thinks them clothes is dry and shuts her down. On autodry the timer motor advances very slowly, The motor does not work while the heating element is on. Only when the heating element is off does the timer motor advance. As them clothes gets dryer the temp inside the dryer stays warmer and therefore the dryer thermostat keeps the heater off long and the timer motor advances. Like being on a highway with traffic jam you go a little bit then stop then go a little bit more then stop. Finally you get there. So what goes wrong? The control thermostat is not functioning properly causing the heater limit to do all the work . Instead the heater limit has to do the work and it ain't a real happy camper. Makes them clothes get too hot. They come out wrinkled.
Aug 30, 2012 | Maytag Dryers
Hello my 70 series kenemore is not getting warm and the timer is not completing the cycle to turn the dryer off it just keeps running for hours
I would need a model number to better narrow the problem down for you.
If this is a gas dryer
Remove the lower panel. With the lower toe panel removed, start the dryer & watch the igniter. If the igniter glows & cuts off without lighting the gas this would usually indicate the gas valve coils are weak & will need to be replaced. For this type of repair be sure to disconnect the electrical power & turn off the gas to the dryer. If the timer is set in the auto dry cycle, it will not advance if the dryer is not heating. Once you repair the dryer, the timer should start advancing. It is possible that your old timer is good. If you need further assistance please resubmit your question.
If this is a electric dryer
The timer not advancing from 50 minutes in time dryer & the unit not heating are not related unless 1 leg of the 240 volt supply is lost. Diagnosing a problem like this will require using a volt/ohm meter. With the timer set to time dry you should be getting 240volts to the timer motor & 240volts to the heating element. In the wiring diagram provided L1 comes from the timer on R & goes through the thermal cutoff, oper thermostat & the hi-limit to provide 120volts to 1 leg of the heating element. The L2 leg goes through the motor switch to the other side of the heating element. This is how the element gets 240volts. The timer motor gets its voltage on BK from L1 & OR from L2; this is what advances the timer.
Jan 12, 2011 | Kenmore 700 7973 Dryer
Kenmore Dryer
I am sorry to hear this, my name is Marc White, i am self employed and it seems as though you have a bad timer, bad timer will cause the timer not to go to the off position and blow your fuse......change your timer..
thanks
Apr 03, 2008 | Kenmore 73952 Gas Dryer
Electrical Supplies Logo
840 people viewed this question
Top Siemens Electrical Supplies Experts
john h
Mike
Gene Haynes
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
