Question about Home
WATER HAS CEASED FLOWING THROUGH THE VALVE - WATER SUPPLY TO REST OF HOUSE NO PROBLEM - NOT A PIPE BLOCKAGE
  • 54 Answers
Washer has come off and is blocking the passage. Remove cartridge and broken washer. Repalce.
Posted on Sep 14, 2009
Crown boiler
follow this chart troubleshooting and fix it. God bless you
est and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electrical panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Drain a tank:
  1. Shut off power at the electrical panel and post a sign warning others not to turn it on.
  2. Close the cold-water supply valve and open a hot-water faucet somewhere in the house (to speed draining).
  3. Attach a garden hose to the drain valve and run it outside the house.
  4. Open the drain valve and allow all water to drain out.
  5. To refill the tank, close the drain valve tightly and open the cold-water supply valve. Also open a nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full and the faucet can be closed.
  6. Once the tank is full, turn the electrical power back on.
Test and replace a relief valve:
  1. Lift the spring lever on the valve to fill a small cup. Check the cup for sediment.
  2. If no water spurts out, or if water continues to drip after the valve is released, replace the valve.
  3. Cut power at the electrical panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
  4. Drain a few gallons of water from the tank.
  5. Unscrew and remove the discharge pipe if used.
  6. Loosen the relief valve with a pipe wrench, then remove the valve by hand.
  7. Apply pipe tape to the threads of the replacement valve and screw it into the tank by hand. Tighten it with a pipe wrench. Screw the discharge pipe (if any) into the valve outlet.
  8. Refill the water heater and restore electrical power.
Replace a drain valve:
  2. Close the cold-water supply valve and drain the water heater completely (see above).
  3. Unscrew the drain valve with a pipe wrench.
  4. Replace the drain valve with an identical unit wrapping the end with pipe tape.
  5. Refill the tank and restore electricity.
Oct 14, 2013 | Water Heaters
Low flow trough the heater
follow this steps and fix it. God bless you
Drain a tank:
  1. Shut off power at the electric panel and post a sign warning others not to turn it on.
  3. Cut power at the electric panel and post a sign warning others not to turn it on. Close the cold-water supply valve.
Oct 08, 2013 | Water Heaters
Water keeps flowing constantly
Sounds like the solenoid valve on your humidifier is stuck in the open position. Shut off the water supply to it from the saddle valve on the cold water pipe as a temporary fix.
Jan 30, 2013 | Aprilaire 600 Humidifier
We own an apartment building that has the old radiator steam heat powered by a gas bolier .. It heats 11 apartments and 3 store fronts. recently 1 of the apartments called and said that they were not...
the steam is not flowing to that radiator because of a blockage in the pipe or radiator, the valve may have an obstruction or the radiator is water bound. Remove the vent and see if the heat improves. If not, you have a blockage in pipe or valve.
Jan 08, 2011 | Heating & Cooling
Top load washer, starts l flowing water normal and
Check if there is not a blockage in the supply pipe or the gauze filter at the connection at the back of the machine.
Jun 24, 2010 | Maytag PAV2300 Top Load Washer
Washer wont fill enough water
Washers have a (vacum pipe) that feeds a micro switch. The air pressure in the vacume pipe caused by the water filling the washer activates a vacum switch when the correct amount of water has entered the machiene. This vacum pipe could be partly blocked or the vacume pressure switch contacts burnt of faulty. This can be tested by physicaly blowing air by mouth into the pipe and you should hear the switch click.
Jan 21, 2010 | Dishwashers
Water dispenser is flowing super slow, almost a trickle. Takes forever to fill a glass. Kids won't even use it anymore.
HI. This will happen if the filter is near its filtering capacity limit. You will need to replace the filter in this case, asap. This will correct the issue.
Note( If the filter is not the issue, a more uncommon issue will be a faulty water inlet valve assembly)
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Oct 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water not flowing through Refrigerator
Check the valve again. It is most likely a needle type valve that pierces the copper pipe.
Turn off the water to that pipe or the whole house. Remove the valve. Check the valve for build up or damage. If necessary replace the valve in the same exact place, other wise you will have two holes and one valve.
This could be caused by two things, hard water or electrolysis. Mineral deposits will form on practically anything. Electrolysis occurs between two different metals, ie copper and probably stainless steel.
May 12, 2009 | GE Refrigerators
Whole house water filter , NO water coming thru
Good morning! please try to uninstall the water filter, then observe if there's water flowing on the tube, if there's water flowing then it might be the shutoff control valve that is defective which mean that we have to replace it. best regards
May 05, 2009 | Plumbing
Water is continually flowing out of my Lenox G26 series furnace
You mean the main plumbing supply to the house? NO WAY! Something is terribly wrong somewhere but not in your unit.
Apr 08, 2009 | Heating & Cooling
Home Logo
159 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
