Question about Sony Cyber-shot DSC-W55 Digital Camera
Compatible Battery problem
I use an original fully charged battery, after 10 seconds the camera thinks the battery is empty en shuts off.
  • 89 Answers
Try clean contacts of the battery. If problem persists, note what is on the LCD when it turns off. Only symbol of an empty battery, or is there any text? If there is written "For InfoLithium/compatible battery only", it does not mean that the camera thinks the battery is empty, but that the battery do not communicate with the camera. If other batteries are OK, you should replace the bad one.
Posted on Sep 18, 2009
  • HAG0221 Jun 18, 2011
    i have the same problem "or use with compatible battery only" and Only symbol of an empty battery, even though i fully charged it btw i have DSC-W330
  • DSC cameras Jun 19, 2011
    You have the same problem, the solution is the same too: try clean contacts of camera for battery and contacts of the battery also, especially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try to use another battery in your camera, or your battery in other compatible product - this way you will determine if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
I accidentally left my EN-EL14 Ultra High Capacity Li-ion battery on the charger for 24 hours at least - is it toast? The manual that came with my Nikon D3200 says leaving a fully-charged battery on the...
Does the battery pack work? Leaving it on the charger for 24 hours shouldn't hurt the pack (too much) since the charger shuts off when the pack is fully charged. The most likely result would be a slight reduction in the capacity, but it should still work.
You shouldn't need to order another battery pack unless it no longer works.
Aug 22, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
I have a Canon G5 and am on my third set of rechargeable batteries (I bought an extra Canon rechargeable battery when I purchased the camera and then 2 Canon brand replacement batteries when the first 2...
Thank you for such a detailed description, wishing others would take your lead. To the problem camera designated batteries (other then AA rechargeable) have always been a bit of a sore spot for me because the user is compelled to purchase a specific battery. As much as I prefer the name brand accessories for the camera there come a point where you just gotta venture forth with third party accessories. There is nothing wrong with using an "off" brand in fact what I've found is that is some cases they are a better battery. Again back to the problem. I grasping thoughts on how to word this but, here goes. As much as the manufactures would like you to believe that these batteries do not form a memory they do. Also the battery can trick you into thinking it's fully charged when in fact even though the charge light is saying completed it's only got about 1/3 charge. I've worked with Canon's BP 511 and now the "new" BP 511A for many years The BP511A or equivalent is the better battery. What needs to be done is to drain those batteries down until they stop, let it cool don't take it from the camera to the charger. Time the battery when you put it on the charger, meaning not to the second but what you would "normally" do is plug the battery into the charger and leave it right. Well what's possibly happening is that within ten minute the ready light is coming on, (something stupid going on in the battery) So check the battery stat of charge after say 15 minutes and if it says it ready (drum roll please) remove the battery unplug the charger for a few seconds and place the battery charger back onto the wall outlet and plug the battery back into the charger and look at your watch again. I've had to do this as much as three times until the thing would get the idea it was to take a charge "normally" about 2 hours will bring it back up. There is no device I've found to completely drain one of these batteries so over a period of time in your case one year the batteries begin this fit. I've since replaced the BP511 for the better BP511A's or equivalent. I'm not pointing a finger because myself and staff do the same thing and pull the battery before going to a shoot if it's showing partial discharge and the thing gets put onto charge and we start this cycle all over again. Be careful of the charger as well meaning don't just disconnect the battery and put it back on charge when it's going the cycle thing disconnect the charger from its power source as well because it holds a memory for a few seconds and will just shut off in a few moments if you don't.
Long story but I've been doing this now for 9 years since the dawn of Canon's 30D Cheers
Jan 16, 2011 | Canon PowerShot G5 Digital Camera
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
The camera comes on when the powere button is
Usually this is a sign that the battery is weak or not charged enough.
Make sure you have either a new battery or the battery is fully charged, then test the camera again.
This camera takes a Sony NP-BK1 Li-ion rechargeable battery (or compatible).
If the battery is good and is fully charged, then there is a problem in the camera, and needs repair or sell it as parts or as is (if repair cost is too much) on a site such as Ebay.
Apr 15, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Battery compatibility
There's not much you can do about the problem because the problem is inside the camera. A faulty component is probably the cause. (I think its receiving more or less that the needed amount of power so that's the error with compatibility)
If still within warranty, take it back to the reseller and ask them for a replacement or get it fixed. If they refuse, ring up SONY.
Oct 02, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Battery life
I bought a few SL400R.. yes I think this is the best camera ever. The battery that came with the cameras always would last very short time, especially in cold weather. But when I ordered new ones online, these would last very long. The specs of the new batteries are the same as the original ones. Go figure. After that I ordered external charger too, so I dont need to use the camera's built-in charger. Works very well.
Jan 23, 2008 | Kyocera Finecam SL400R Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
248 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
