Question about BoxWave Corporation Blackberry Curve 8320 DirectSync - Car Charger Bundle
Same thing - my BB turns off and on again by itself.
This happens several times a day. I was reading forums and discovered that there are quite lot other BB user with similar prob. Mine is Curve 8330. Some people solved it by replacing battery but before doing that I'd rather try something else. It doesn't matter where I am or time of the day.. It happens anywhere and at any time. How I can do hard restart or reboot?
Please help, I'm new BB user and I'm in love with it :-)
What's your problem?Toyota Prado Grande 2004. Hissing sound at the rear air suspension and it drops (the body). Does not happen all the time. Bounces a lot quite often noticibly on a hot day, does
If you have Air suspension this can happen. The noise you hear like from an engine is actually the airpump trying to keep up.
The hissing is air escaping and the bouncing is an indication that the suspension is not fully inflated.
There are individual bleed valves so the system can be leveled by itself. The valve on one suspension unit may be leaking. Sometimes soapy water sprayed while the part is working and again while shut off will show a leak.
Some Makes have a diagnostic plug which a scanner can read to find the problem. Often a car is jacked or lifted on a rack and someone did not turn off the Air system and knocked it out of alignment.
I hope my solution is helpful and enables you to diagnose the problem now.
Jun 06, 2012 | Toyota Cars & Trucks
My bb hangs a lot. there is a java.lang error which appears after every restart. have to restart the instrument nearly 7 to 8 times a day. am really fed up with the speed as well.plz...
Sounds like one of your apps is crashing the phone. Your best option is to do a factory wipe on your BB, download the latest code from the Blackberry website, and load your apps one at a time to see if the problem is gone.
May 28, 2011 | RIM BlackBerry Storm 9530 Smartphone
Stability control fail then engine fail mode i had this problem for a while it was on and off recently it happen more quite often. whenever it happen I had to turn off the engine and restart it again...
This problem is due to the malfunction of the computer fitted in the car. You better reset the computer simply by pulling out the battery terminal cables for at least 10 hours and in the mean time clean all the sensors related to the stability systems like wheel etc. Then re fix the battery terminals cables and enjoy your drive.
Jul 22, 2009 | 1999 Jaguar XK8
On my kenmore 90 series dryer the barrel won't turn
most of the time when that happens it's the dryer motor getting weaker and weaker until one day it just stops and then all you will get when you push the start button is a buzzing sound,i see this all the time on kenmore"s-mike
Apr 22, 2009 | Kenmore 62602 Electric Dryer
Tv will shut off while viewing. standby light flashes.
The problem with your Sony. This is a common problem with these Sony sets.
1. How many times does the light blink? Is it consistent and continuous?
2. Does anything happen to the picture itself, or does the set just turn off?
Answer that and I can help you.
Nov 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Radio turns off by itself
phone has been dropped there is a key sticking or hair line crack in mother board of phone
May 13, 2008 | RIM BlackBerry 8700g Smartphone
BoxWave Corporation Blackberry Curve 8320 DirectSync - Car Charger Bundle  Logo
49 people viewed this question
Top BoxWave Corporation Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a BoxWave Corporation Cell Phone Expert? Answer questions, earn points and help others
