Question about Boating
I have a 1970 evinrude 115 hp outboard. which when I first got it, had not been run for about 8 years. I removed the plugs, oiled the cylinders, and made sure I could turn it over by hand before I cranked the starter. It started. Then we tried the lake. It ran fine for about two hours then started running realy rough. Limped it back to shore. Took it to a shop. that replaced the water pump impeller. I've rebuilt the carbs replaced the plugs,replaced the coil. Still fails. the shop it's at right now has replaced the trigger wheel. and the black box still with no luck although now it won't run at all. no spark. ANY IDEAS ?
I would say that this is a problem with the power pak. I have replaced at least six of these. It seems Evinrude had a lot of problems witrh the power paks. I just replaced one wit a new one and the new one is bad too. So, have ordered a replacement unit and It is under warranty. The only prtoblems that I have ever had with my motor over (which I bought new in 1970) has been the power paks. Otherwise, it runs great.
Posted on Oct 06, 2009
  • 285 Answers
A couple other things to check... Is the stator still good? This provides the electric current to provide spark to the plugs. The magnets under the flywheel also need to be in good shape. Sound sliek these havent been checked as yet. If they are good, the next thing I would check is the actual spark plug wires themselves. These can degrade and require replacement as well. Just take it bit by bit and hopefully you will find the problem, but those are the two things I would check next because it appears you have replaced just about everything else!
Good Luck
Posted on Sep 04, 2009
2003 2 stroke evinrude 225 hp outboard will run at high speed about 5-7 min than starts shaking seems like not all cylinders are firing. if i shut off the motor and restart it will run another 5 min.
check the plugs if they wet its getting too much oil in the mix. if dry and black plugs then it could be not enough oil or fuel in mix.
Jun 21, 2017 | Cars & Trucks
Evinrude E-tec 115 hp 2007 model No power to engine or hydraulics
Sounds like a fuse has blown, look behind your dash panel.
Mar 15, 2017 | HP Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
I have a 1985 Evinrude 60hp outboard that i removed the oil injector so as i could run on mixed fuel. At high speeds it is bogging out and seems to be missing badly. Could this be the wrong fuel/oil mix,...
The correct mixture is 50:1, or 1 pint per 6 gallon tank. Use quality brand-name outboard TCW-II or better oil(Bombardier or Mercury eg.) to eliminate the oil as a problem.
Check your plugs for fouling. If using perma-gap / surface-gap type plugs, switch to the L77JC4 type, especially for long idling or slow speed operation. For extended high speed operation, the surface gap plugs are recommended.
Jul 12, 2011 | Clymer EvinrudeJohnson Outboard Shop...
How to access carburetor for applying fogging oil in 1989 140 hp evinrude outboard?
The fogging oil does not go in the carb. It goes in the cylinders. You have to remove the spark plugs and spray the fogging oil into the cylinders. Turn the motor over a few times with the plugs out , respray and then replace the plugs. You are protecting the cylinder walls by doing this. hope this helps you. Jeepfxr
Nov 08, 2009 | Boating
1970 115 evinrude wont start
remove starter and try bench testing the starter...if it works you have problems with the engine...
Oct 09, 2009 | Sport & Outdoor - Others
Boating Logo
214 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
