Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie d40 locks up when I put the sd card in???
Tried clearing out memory and everything suggested but nothing seems to work.....
  • Ronald Lockhart May 11, 2010
    IS THE SD CARD SWITCH PUSHED TOWARD CONTACTS
  • Moultrie Expert
  • 296 Answers
Make sure card lock switch is forward toward contact strips fully.
Posted on Feb 20, 2010
My Moultrie M880 game camera is set to take 3 pictures, so once I place the SD card in turn on and I have in a area with no moving grass or limbs the camera will take pictures non stop. I will check i
Post subject: Re: M880 problem Solved .... icon_post_target.gifPosted: Tue May 27, 2014 3:48 pm icon_user_offline.gif
First of all, ONLY USE THE STANDARD SPEED SD CARD THAT MOULTRIE ADVISES.
Second, DO NOT TAKE THE CARD OUT & USE A READER WHILE LEAVING THE CAMERA MOUNTED (this will lock up the camera).
Third when using a brand new standard speed sd card, DO NOT FORMAT THE SD CARD IN ANYTHING OTHER THAN THE CAMERA.
One could clear the camera by reseating the battery (take the battery out & put it back in). The reset button (up inside) is not always necessary for this.
You probably got a different speed card to somehow work & the camera malfunctioned. Bear in mind the aforementioned advice.
Nov 29, 2014 | Moultrie Cameras
Menu screen nothing but lines.
Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Mar 02, 2014 | Moultrie Game Spy D555i Trail Camera
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
Everything seems to be working fine. timer, flas etc and it seems to be taking pics but when you check it there are none. have tried two different cards no luck any ideas
Remove card go to setup scroll until you get delete all images;select;up or down button to change no to yes;select..turn off and try card again.Have to delete internal memory to use SD card.
Sep 17, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
SD card Locked
The error code 000060 means SD card locked. The switch on your card may be unattached internally. Try a different card.
May 17, 2010 | Moultrie MFH-DGS-200 Digital Camera
Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Oct 20, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Apr 11, 2009 | Moultrie MFH-DGS-100 Digital Camera
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
417 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
