Question about Garden
I am installing new piston rings in a kohler cv13 because it started smoking a bit, and i am not sure if i should go with .25 bigger on the rings or .50 bigger---mid to late 80,s john deere stx 38, thanks.
  • 548 Answers
If you have a micrometer you could measure the size difference but if you dont you go with the next size over normally which would be the .25
Posted on Sep 03, 2009
Pulsar 220 Bike emits little smoke even after Rebuild, how do I fix?
Did you clean the bore REALLY REALLY good with hot soapy water and a brush before assembly? Need to remove all the grit from the honing process. Test by rubbing hard with a white cloth.It MUST still be white after rubbing. If not then clean it again. It will wear out the rings quickly if it's not right. Solvent will not clean it properly.
Jun 24, 2015 | 2007 Bajaj Pulsar 180
26hp kohler engine started smoking suddenly. still runs good.whaat would cause this problem.
Head gasket blown. This is a very common issue with these V twin Kohler engines. There is a kit you can order from Kohler that includes gaskets and new improved head bolts. Simple hand tools is all that is needed. You will need an inch pound torque wrench. Torque specs are included in the kit.
Jul 23, 2014 | Craftsman Garden
Smoking white
Probably going to need new piston rings. Pretty sure your burning a little oil.
Feb 10, 2014 | Suzuki Motorcycles
Recently had my 2003 VW golf serviced (engine flush & oil change). It was running well before the service but on the way home after the service it began blowing white oily smoke everywhere. We took...
I had a similar experience with a 1970 Plymouth Duster, at 10 years old (1980) I flushed the engine and started running a little bit higher detergent oil and it also started smoking as you described,turned out with the engine as clean as it got the clearances of different internal oil retaining parts such as valve guides and piston rings were slightly bigger causing my engine to smoke,
Feb 02, 2014 | Cars & Trucks
Low oil & smokes - 2yrs old
The piston rings need to be replaced. The cylinder might need to be bored out bigger, then put in
a bigger piston.
Hope this helps.
Oct 25, 2010 | Briggs Stratton IC Horizontal OHV Engine ...
I'm working on a kohler cv730s 25 hp engine came in with bad rings smoked alot put new rings .08 o/s is all anyone stocked new valve seals head gaskets ran the engine at idle shut it down waited 15 min...
you need to replace the cylnder and rings at same time.
Just replacing the rings with a worn cylnder will not stop oil leakage and blowby.
Aug 16, 2010 | Garden
I rebuild my engine an it is smoking when running. I intall new pistons and rings. I think that the problem are the rings that have to be a size greater than standard (.25)?????? HOW TO FIX THIS PROBLEM?...
first you should have check your engine block to see what wear it had before you buy new piston. that will determin what oversize piston and rings to used , will if it come to that , it areally waste of work done
Aug 04, 2010 | Nissan Sentra Cars & Trucks
1974 TX500, high idle, white smoke from breather tube
The idle problem is a lean fuel mix caused by an air leak in the intake system. Bad gaskets /seals on the intake manifold, bad valves, bad piston rings, loose spark plugs, and bad head gasket are all things that can lean the fuel/air mix. The smoke indicates a need for new rings. I would have the cylinders bored then install new pistons and rings. Now finish the top end work by getting a valve job. You should get a liquid fuel tank liner to eliminate any rust problems in the future. Also, install an in-line fuel filter. Google “ kreem fuel tank liner “ or go to www.http://www.4secondsflat.com/Fuel_Tank_Sealer.html
My complements on the well cleaned carbs. Do the work mentioned above an you will effectively have a new engine.
A “very helpful” rating for this answer? Thanks!
Jun 11, 2009 | 1973 Yamaha TX 650
Worried about the cylinder
Give the rings and cylinder some time to break in. They need to get to know each other.
Apr 11, 2009 | 2004 Yamaha YZ 250 F
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
