Question about Dryers
Dryer drum will not spin when you push start button.
Dryer will come on when you push the start button but drum will not spin. You can turn the dryer drum manually but it won't turn on it's own with the motor going. There is a smooth knob like thing on the back of the dryer that spins when the drum spin and the little knob like thing won't spin now.
  • 574 Answers
Can you hear the motor running? if so its probably a broke belt
Posted on Sep 03, 2009
Testimonial: "Thanks so much roberta3fan. "
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
I push start button and it humm's and dosen't spin i open the top of the dryer and then push the start button and the push the drum to jump spin it and then it work's.any thought's
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
When pushing the start button dryer hums but does not spin. when u release start button dryer shuts off
Sounds like a bad motor. Check to make sure the drum isn't stuck, if you can spin the drum put some tape on the door switch and press the start button while you spin the drum. If the drum continues to rotate, you have a bad motor.
Mar 10, 2011 | Maytag Washing Machines
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
Dryer doesn't run
the motor is going bad..push in the door switch on the dryer,an it start an spin the drum ,it it works,replace dryer motor,or purchase a new open....turn start button,pusn in door switch,spin drum by hand...all at same time....hope this helps...dryer may run a couple of times...good luck...michael..doctor airr appl.repair...843-384-8474....
Mar 26, 2010 | Dryers
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Dryers Logo
821 people viewed this question
Top Dryers Experts
