Question about Toshiba 32AV500U 32 in. LCD HDTV
Have a jumbo universal remote and cant set toshiba 32av500u code
I tried all the toshiba list code but non of them make the tv respond. do some one has the correct code? help please!
  • 60 Answers
SOURCE: Code for Magnavox Univ remote
Try one of these codes:
018, 021, 023, 071, 085, 090
If those don't work, respond with the model for the remote and we'll try some others. Also, if remote requires 4 digit codes, just put a 0 in front of each of the above.
Posted on Apr 06, 2009
  • 15 Answers
SOURCE: My Toshiba 32AV500U - the picture went blank.
This problem usually happens when the lamp runs out, verify how old is your TV, lamps have a life spend of aprox. 3 years, most likely you would have to replace the bulb so your TV can start running again!!
Posted on Mar 17, 2010
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
  • 8457 Answers
SOURCE: 32av500u toshiba remote is having problems. Some
The tv remote CPU is shorted and dead.Try website like Remotes.com to buy an exact remote to the original remote.
Posted on Oct 24, 2010
AJIN G
  • 6694 Answers
SOURCE: PAVY universal remote.I need a code to a Toshiba tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Posted on Jan 12, 2017
All in one remote won't turn TV on Toshiba regza
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
To get more set-up codes, Visit the following sites.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Feb 20, 2016 | Toshiba Televison & Video
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
I need the codes to set my jumbo universal remote for dvd toshiba d-rw2
2865,2894,2850,2881.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Aug 26, 2014 | Emerson Jumbo Universal Remote Control
Alba tv code for jumbo universal remote control
0384 0421 0457 0460 0610. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 29, 2014 | Innovage Jumbo Remote Control
Need the code for toshiba tv
Google search with the model number of the unit for "manual" for a owner manual with a possible list of codes to try. Remember that universals have a limited number of codes built into them--may or may not have the one you need.
May 23, 2012 | Toshiba Televison & Video
I want to program my oneforall universal remote to my toshiba tv
Hello
To programme your Toshiba TV with One for all URC 5800 Cenema 5+ remote as follows.
[1] Turn on your TV
[2] On the Cinema 5, press TV and release. Press
and hold SETUP until the red light blinks twice,
then release SETUP
[3] Enter the first four-digit TV code listed for your
brand. If performed correctly, the red light will blink
twice when you enter the final digit
[4] Aim the Cinema 5 at your TV and press POWER.
The TV should turn off. If it does not respond,
repeat steps 2-4, trying each code listed for your
brand until you find the one that operates your TV.
NOTE: If you have tried all the codes listed for
your brand and your TV does not respond, try
using "SEARCHING FOR YOUR CODE".
The codes for Toshiba are:
0156, 0060, 0154
OK.
May 12, 2011 | Televison & Video
I have a jumbo emerson universal remot and I hava a toshiba dvd and vcr combo an i need the codes
105,162,160 are the codes for toshiba tvs,
013,049,089,105,109,117,118,120,159,178 are also listed for peripherals.
May 07, 2011 | Innovage Jumbo Remote Control
Ihave an old Toshiba tv and a Systemlink 3 romote. I lost the code book, please send me the codes. Thanks
The codes for Toshiba are: 049, 071, 072, 089, 105, 109, 117, 118, 160, 162.
1.Find the three digit code(s) for your TV set.
2. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
Good luck and I hope this helps. Thanks for using fixya.
Jan 03, 2010 | Toshiba 27A33 27" TV
Jumbo remote codes and steps
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button, for TV's not on the list.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Dec 16, 2009 | Innovage Jumbo Remote Control
Apr 06, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Toshiba 32AV500U 32 in. LCD HDTV Logo
148 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
