Question about Polaris Pb460 Polaris Booster Pump Replacement O - Ring
Wiring on my Polaris booster pump came loose and I don't know where to put the wires. I have one purple and one orange wire. Pump operates on 110 volts. Any thoughts?
  • 128 Answers
The label on the motor has a wiring diagram for both 110 and 220
Posted on Sep 05, 2009
My power supply has 3 wires, red, black and white. Pump wiring diagram has 6 posts for 1 yel w/blk, 2 brown, 4 black, 5 orange white 6 yellow. There is no red. what goes where?
see side of motor check voltage between red and black should be 220 red and white 120 volt black and white 120 volt make sure wiring is still for 220 from factory black to L1 red to L2 white to ground make sure white in box goes to green bus
Aug 01, 2013 | Polaris Booster Pump and Motor 34 HP
Polaris Booster Pump Brand New keeps shutting off
if wired 120 check side of motor rewire for low voltage
Jul 22, 2013 | Polaris Pb4 - 60 Booster Pump
Wiring a Polaris 280 booster pump motor
if connecting 120 volt see side panel for wiring change from 220 to 120 volt move brown and white wires then black to L1 white to L2 then green to ground or case
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
Polaris pool pump wiring
check voltage with a meter if ok and you check your wiring could have a bad motor from factory double check first
Aug 11, 2012 | Polaris Pb4 - 60 Booster Pump
Polaris pump turns on 10 seconds and then off then on and off
check wiring 220 vs 110 volt see side of motor for schematic check voltage first
Aug 04, 2012 | Polaris 280 In - Ground Pool Cleaner with...
Can you send a scematic showing how to wire an intermatic pool pump timer to a polaris intermatic timer so that when the pool pump shuts off so will the polaris pump yet the polaris timer clock continues...
No. I don't have a wiring schematic without knowing what voltage you are using, specifically what Intermatic timer you have, specifically what wires you have coming from breaker box, what wires are on the pump, and what pump rating plate says, what the wiring diagram shows on side of pump, whether you are wiring a 2-speed pump to a single-speed timer, specifically what is the polaris timer clock, and why this pump needs two timers if that's what you mean.
Add a comment with specific information so electrician is not guessing.
http://www.poolcenter.com/polaris-booster-install-OM.pdf
Open following link for 240Volt T104 timer wiring diagram.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Aug 25, 2011 | Intermatic T104 24h 208-277v Mechanical...
Wiring diagram for Polaris booster pump
http://www.electricmotorwarehouse.com/PDF/polaris_manual.pdf
If you goto this link and scroll down to page 4, it shows what the wiring is.
Hope this helps. If so, please rate me for this.
Oct 29, 2010 | Polaris Booster Pump and Motor 34 HP
Looking for wiring instructions for the pb4-60 booster pump
if this is for your polaris booster pump they all have to screws to attach the wires if you have 220 volts it won't matter which wire goes where the longes the pump is rated for 220 volts if you have 120 volts pump is the same just make sure your wires are for 120 volts it won't meter which wire goes on which side just make sure you use L1 AND L2
Jun 15, 2009 | Polaris Pb4 - 60 Booster Pump
Looking for wiring instructions for the replacement polaris pump motor. It says it is wired for 240 and I need the configuration for 120. It is polaris booster 3/4 hp pump.
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Apr 24, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris Pb460 Polaris Booster Pump Replacement O - Ring Logo
455 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
